Homing vs. Printing height difference
When I do that (for the 10th time) I get a probe not triggered response when running a G32. I know the probe triggers when pushed because the LED on the board goes off. If I increase that trigger value, it still doesn't work because the probe remains too high. If I decrease the trigger height value to 15.22 I get a calibrated mean deviation response after G32. All Good. I then enter an M500 to save it. And when I go to print, The extruder prints in midair about 4.9mm above the bed.
How did you measure the trigger height?
I take the indicated difference from the point at which the probe triggers, remove the probe, and then lower the extruder until the nozzle touches the bed. The total distance is appx. 20mm (15.3 + 4.9). When using that value, the probe doesn't trigger when G32 is used. If I lower the trigger height value to 15.4, the probe triggers. Then I get a mean deviation report, hit M500, and go to print... 4.9 mm above the bed... again. Pretty frustrated here.
If you home the printer and then move to Z=0 where does the nozzle end up, height wise?
4.53mm above the bed
@1d1 said in Homing vs. Printing height difference:
Do you have a line like this in your config-override.g file?
M665 R106.35 L215 B180.8 H224.5 ;Set delta radius, diagonal rod length, printable radius and homed height
If you do change the H parameter to H229.4
If not change that line in your config.g file.
Then re-boot, home and move to Z=0 and see what happens.
@jay_s_uk Many times.
@fcwilt I'll try that. Though I have already in the past, maybe we're closer to the solution...
Well you're doing to z probe offset the wrong way.
Heat the bed
Heat the nozzle
Take the nozzle down until it's touching the bed (using paper to determine when they're touching)
G92 Z0
G1 Z30 (to move the nozzle away from the bed)
Fit the probe
G30 S-1And the offset will be spat out
OK. Adding 5mm to my overall homing height didn't alter results, but I left it that way and did the G92 Z0 process again and we have ignition. A number was spat, changes were splatted and results regurgitated. PETG flows properly once again. Thank you both (all?) for your help.
Adding the 5, reboot, home and still Z=0 came out at 4.9? Very odd.
Well, anyway, don't leave us in suspense - what number was "spat"?
@fcwilt thats what it says to do on the wiki
@jay_s_uk said in Homing vs. Printing height difference:
I understand and it is a perfectly fine solution.
Sorry - had to step away. The homing height in M558 is locked at 229.4 and the number spat is 19.43. Still needs a teensy bit of fine tuning, but the grand picture includes printing again.
