Mesh compensation no longer working in RRF3
I use an inductive sensor wired to the e0stop and I used to be able to do mesh compensation and use the bed leveling assistant but now it's giving me the error G30: Z probe 0 not found. It looks like G29/30 can only use probe 0 which look like it should be setup by default from the wiki on M558. Is my "Z probe connected to E0 endstop input" not a z probe? Or how should I perform G29/G32 operations now?
; config.g ... ; Define Position of Bed Leveling Screws M671 X11:296:153 Y0:0:280 ; Endstops M574 X1 S1 P"xstop" M574 Y1 S1 P"ystop" M574 Z1 S1 P"!e0stop" ;X & Y are active high ;Z is inverted, see M558 below ; Set Z probe type M558 P5 C"!e0stop" H3 F120 T18000 G31 X5 Y-47 Z0.5 ; Set Z probe trigger value, offset and trigger height. Higher value brings nozzle closer to bed ; (this G31 line must come *after* M558 line) ...
; bed.g ; called to perform automatic bed compensation via G32/29 M913 Z70 ; Reduce Z motor current so if the Z sensor fails ; and there's a head crash there's less force M561 ; Clear any existing bed transform G29 S2 ; Clear previous height map G28 ; home G30 P0 X11 Y0 Z-99999 ; probe near an adjusting screw G30 P1 X296 Y0 Z-99999 ; probe near an adjusting screw G30 P2 X153 Y253 Z-99999 S3 ; probe near an adjusting screw and report adjustments needed M913 Z100 ; Restore Z motor current currents
Your issue if you're trying to set the same pin as a z endstop and a z probe.
Just remove the M574 for Z
@gamer_013 said in Mesh compensation no longer working in RRF3:
replace with
M574 Z1 S2 ; configure Z-probe endstop for low end on Z -
@jay_s_uk said in Mesh compensation no longer working in RRF3:
Removing this line gives me a "failed to enable endstops" error when trying to home Z.
@Veti said in Mesh compensation no longer working in RRF3:
replace with
M574 Z1 S2 ; configure Z-probe endstop for low end on ZThat did it! I didn't think so try that as the gcode wiki said "The S2 option of M574 is intended for use only when axes other than Z are using the Z probe for homing." Which confused me because I was using my "z probe" to home the z axis so I didn't consider the S2 option. Thank you!
@fcwilt said in Mesh compensation no longer working in RRF3:
JOOC why are you not using the Z-probe connector?
This is carried over from an old config that I used long ago and the example happened to have it setup that way. I may convert it over when I get some time to re-configure my printer.
