HOW change the speed of my bed calibration G32 AND G29
that is F
@Veti ok thnks now its work I had to add a lot of speed to see change in tnnn
@Veti now the speed work good thanks but ihave Another problem is it never starts from point X0 it always moves a bit to the side and starts doing bed calibration how ifix it ,You spot something wrong in my
config settings -
@Roei3d said in HOW change the speed of my bed calibration G32 AND G29:
M557 X0:235 Y20:225 S30 ; define mesh grid
this just says there is a spacing of 30 between the points.
235/30 is not an even number, so it does not fit perfectly.
also you have an offset
G31 P500 X38.2 Y0 Z1.08 ; set Z probe trigger value, offset and trigger heightbut if there are no warnings during the probing you are fine.
ihave dde direct drive kit this is th right X Y OFFSET ,
but iget this error
Warning: Skipping grid point (0.0, 160.0) because Z probe cannot reach it
Warning: Skipping grid point (0.0, 200.0) because Z probe cannot reach it -
M208 X245 Y210 Z240 S0 ; set axis maxima
M557 X0:235 Y20:225 S30 ; define mesh gridyou need to limit your grid taking into account the probe offset
M557 X40:245 Y20:225 S30 ; define mesh grid
@Veti this is my problem ido home all
After it g29 and its not start from x0 it dont go all to the end stop
I upload to you tube https://youtu.be/7FL0kCXGIHM -
nice the new metal kit for the ender.
again it does not need to go to the endstop for probing.
@Veti thnks its blv ender 3
itray this M557 X40:245 Y20:225 S30 and it goo out of the bed -
ok change to this
M208 X235 Y210 Z240 S0 ; set axis maximaM557 X40:235 Y20:225 S30 ; define mesh grid
ender 3 is max 235. why did you define 245?
@Veti hi clean the nozzle with a brush I put aside on x245
if ido M557 X40:220 Y20:225 S30
no its work good no error its ok ?
26.9.2020, 18:34:28 G32
49 points probed, min error -0.347, max error 0.734, mean 0.164, deviation 0.288
Height map saved to file heightmap.csv -
yes.
post a picture of the heighmap.
This post is deleted! -
i am not sure of you are twisting your bed. try adjusting the top right to be in line with the other sides
@Veti ok thnks for your help
