hbot homes correctly but prints mirrored ,
@Phaedrux
are you aware of anywhere i can download differnt macro files for differnt things, fully auto scripts, manual stuff.... dont care what they are, just want to find, learn, modify , try things out see what i can do with this printer. if you have any stuff you can pass on to me , please send me a file with a side of everything -
You can take a look at mine if you like.
https://www.dropbox.com/s/td86jdrztubq2dg/macros.zip?dl=0
https://www.dropbox.com/s/k25fuhdrr7c3miy/Config V22.zip?dl=0
@Phaedruxnice, Thanks this gives me hours of hair pulling fun
after upgrading to 3xx this wont save its probe data
what needs to be changed?; bed.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 02 2020 19:54:07; BLTOUCH PREP
M400
G4 S1
M280 P0 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
G4 S1
M402 ; Retract probe just in case it's down
M400
M561 ; clear all bed compensation
G28 ; home all axis
G90 ; absolute positioning
G1 X220 Y330 Z10 ; move probe to center of the bed
G30 ; set Z0 position with the probe
;G1 Z25 ; return to 25mm height
G30 P0 X440 Y330 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X0 Y330 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
G1 X220 Y330 Z25 ; move probe to center of the bed
M500 P31; save results
M501 ; load new data
M280 P7 S90
M402 ; retract probe -
@tracar said in hbot homes correctly but prints mirrored ,:
M280 P7 S90
If you're on RRF3 P7 should be P0
Does it work if you put a space between the P31 and the ; ?
The only issues I am aware of with M500 is that it's currently not supported with the Duet 3 when used with a Pi.
Do you get any error messages if you send M500 by itself?
If you delete your config-override.g and send M500 does it get created?'
Actually, looking again, it doesn't look like you're using G30 S-3 to measure the probe offset with this macro, so M500 P31 isn't going to do anything here. What are you expecting it to save?
@Phaedrux
i moved the m500 and m501 below the line under the 501, seens to work and generate the correct offset and save it in a newly created config override file correctly......as i deleted to test with m32
verified by homing z, droping the table and baby stepping up till the probe is triggered. the z axis ,matches what was automatically storedno error message when send m500.
; bed.g
M400
G4 S1
G4 S1
M400
G28 ; home all axis
M280 P0 S90
G28 ; home all axis -
Since you haven't changed it with a G30 S-1 it's just saving the same value as before. There is no reason in this macro to have M500 or M501
This post is deleted! -
@Phaedrux
; bed.g
M400 ; Finishes all current moves and clears the buffer
G4 S1 ; wait 1 second
G28 ; home all axis
G1 X220 Y330 F8000 Z10 F800 ; move probe to center of the bed
G30 S-1 ; set Z0 position with the probe
M402 ; retract probewhat im trying to do is have this auto level the bed. and figure out how to keep this new probed info after another homez or homeall is called, say like starting a print.
Well it will stay in effect until the motors are de-energized. It should stay leveled through a G28 unless you're changing the position of individual motors in your homeall.
G30 S-1 ; set Z0 position with the probe M402 ; retract probe
Don't do that. The G30 S-1 is only for determining your trigger height. You don't need or want to do that after you've done the tilt correction. Just do a single G30 at the center of the bed to redefine the Z0 position because the tilt correction will change it slightly. Trigonometry and all that.
If your G28/homeall homes the Z axis, you don't need to do that again at the start of the leveling points. Just after.
; bed.g
G28 ; home all axis
M402 ; retract probeAlso keep in mind that the tilt correction for the bed is only in one axis. It can't correct for tilt along Y. You might also need to run the G32 a couple times to get the tilt completely corrected, and depending on the repeatability of the probe you might end up bouncing around in the noise. So try and get it leveled up as best as you can manually to begin with.
After it's all leveled you may want to run a G29 to get a heightmap of the bed surface itself to see how it looks.
@Phaedrux said in hbot homes correctly but prints mirrored ,:
flawless !!!
you rock.
