hbot homes correctly but prints mirrored ,
This time I think I'm correct , because after looking at your config.g and homing file I could not find a fault.
Your machine looks a bit of a beast !!!
I tried to making my own version of the cr10 and over killed it to the point where it just printed so bad , In the end just got a ender 5 plus.closed loop drivers ? , do you just connect the wire which was going to the steppers are use external drivers ?.
@peter247
closed loop drivers are the ones for steppers with encoders built in.
the steppers wont skip and loose track of their position even if you push an axis out of position. it will self correct....., its all good but if the belt skips then it will loose position. really good for systems with ball sxrews. -
@tracar said in hbot homes correctly but prints mirrored ,:
y+ will move the head towards
Your Y axis is flipped. +Y should go to the back. -Y to the front. This places 0,0 in the front left corner.
See this post on what you must set based on your physical printer and then what you need to change to make that work.
https://forum.duet3d.com/topic/18241/duet-2-wifi-bltouch-issues-on-ender-5-pro/37?_=1598300832742
I think he is using the version 3 config.g and still on firmware version 2 , so I think it just ignores parts of the config file and works in a default way.
@peter247 said in hbot homes correctly but prints mirrored ,:
Yup you're totally right.
To update to RRF3 you need to upload these two zip files as is one at a time to the /sys folder using DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N8PS4-7J9D4-3S86R-KAA3N
Used output buffers: 7 of 24 (10 max) -
i tried v3 but didnt have enough brain power at that time to change all the needed files for it to work.
@Phaedrux
0,0 is in the rear left cornerfront right corner is x440,y535
Your config files are already using the format for RRF3, so you'll either need new files for RRF2 or update to RRF3.
@Phaedrux
See my linked post earlier about why you want 0,0 to be the front left corner. At the very least to understand how to get your prints unmirrored.
@Phaedrux
i understand that if i modify my physical layout, i can achieve the goal of the correct homing direction .and thus a non mirrored printBut my original question is Can it be changed in the software as so i dont have to change anything physically.
with every cnc i have built. i can easily tell it what dir to home and what axis. this plastic printer just boggles me . lol
I'm not saying you have to change anything physical. It's all software settings. If you read the post I linked it tells you what had to be set based on your physical printer.
0,0 is just a coordinate. Putting it in the front left matches the slicer and cad software coordinate system.
The endstop position is irrelevant. It can be anywhere you want. The firmware just needs to know where it is based on 0,0 being in the front left.
Your homing moves are set in the homing files. The direction has to move towards the endstop.
The direction the motor actually goes is determined by the direction of rotation which is also defined in software.
its a bit much for me, i did upgrade to 3.11 but then it took me 3 days to figure out how to downgrade and get the wifi part to connect.. im more a hardware kinda guy. this software is a p-i-t-a for me.
so can you show me a visual example of what i need to change in the code ?
Sure. Post your current config.g and the results of M115 so I know what firmware you're currently on.
Physical location of endstops is left and rear correct?
Do a M122 again , so we can make sure you are on version 3.1 of the firmware.
@Phaedrux said in hbot homes correctly but prints mirrored ,:
M115
currently:
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 27 2020 12:25:17 GMT-0600 (Mountain Daylight Time); General preferences
G31 X0 Y0 Z0 P25
M550 P"Duet2" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P5 S1 T5 R1 ; physical drive x axis goes forwards
M569 P6 S1 T5 R1 ; physical drive y axis goes forwards
M569 P7 S1 T5 R1 ; physical drive z axis goes forwards
M569 P8 S1 T5 R1 ; physical drive z2 axis goes forwards
M584 X5 Y6 Z7:8 E3 ; set drive mapping
M92 X200.00 Y200.00 Z800.00 E138.2316760023409 ; set steps per mm
M566 X200.00 Y200.00 Z200.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X25000.00 Y25000.00 Z2500.00 E2400.00 ; set maximum speeds (mm/min)
M201 X400.00 Y400.00 Z400.00 E400.00 ; set accelerations (mm/s^2)
M208 X440 Y535 Z900 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; set active high endstops; Z-Probe
M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points; Heaters
;M575 P1 S1 B57600 ; enable support for PanelDue -
Still version 2 firmware and running 3.1 config.g
DOWNLOAD , BUT DON'T UNZIP.
Go to the system tab and click update system file , find and select Det2and3Firmware-3.0.zip .
If it says your our running 3.0 with m122 repeat with the 3.1 file. -
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
