Inverse print - duet3D 2 WiFi - cura - cartesian Printer
Post your config.g and homeall.g
Where are the endstops physically located?
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 11 2020 22:45:06 GMT-0700 (PDT); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E833.00 ; set steps per mm
M203 X6000.00 Y6000.00 Z6000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z500.00 E250.00 ; set accelerations (mm/s^2)
M208 X160 Y156 Z177 S0 ; set axis maxima; Endstops
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:15 Y15:15 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M563 P0 S"Tool-0" D0 H1 F0 ; define tool 0
Standard configuration and a G92 set Z zero position
Z and X seem to be OK
Y seems to be invertedand
M98 P”homex.g”
M98 P”homey.g” -
Is the Y endstop at the front or the back of the machine? It's configured as low end, but where is it physically located?
X+ should move to the right, X- should move to the left.
Y+ should move the nozzle to the back of the bed.
Y- should move the nozzle to the front of the bed.Also post your homex and homey files.
Also what is in your slicer start gcode?
My figuration
Is
Y = axis mounted on Z
X = bed plate axis
Z = vertical axis of courseAre you possibly sayin my X and Y are reversed
Should be?
Y = bed plate axis
X = axis mounted on Z
Z = vertical axisVery possible, I just followed the schematics from the Cetus MK 3 drawings - which is the base cord hardware - just replace the extruder, Hotend and motherboard
Actually that would be cool if it was, because that would probably solve the problem
@supset shit, is that it,WTF
@supset said in Inverse print - duet3D 2 WiFi - cura - cartesian Printer:
tiertime has a habbit of swapping x and y, and randomly inverting axis as well. probably the reason some use the endearing term teartime instead of tiertime...
@bearer A little earlier research, I would’ve figured that out,... WTF lol
So far so good, carbon fiber nylon.
after the fix, I can print without inverting first
This is basically a a Pinto,With new hardware worth more than itself
Thanks Gentleman!
well, most tiertime users are none the wiser as their slicer hides the facts that they swap and invert things so unless you go "off-piste" its not something you're like to find out - and even then its not well documented at all.
Looks like you've solved it. I didn't realize that the Cetus was switched up like that.
