Duet wi fi + duex 5 - drivers faults
hi,
im using duet wi fi + duex5 expansion board for a while,
the setup is a Cartesian printer with multiple tools.
firmware version: RC-12 _3.0
web cotrol: version 3.1.1here is my config file:
; Configuration file for Duet 0.6 (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 17 2020 18:15:06 GMT+0200 (Israel Standard Time) ; General preferences G21 ; Work in millimetres G90 ; Send absolute coordinates M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like Marlin M568 ; tool mix ratios on M302 P1 S0 ; Allow cold extrusion minimum of 0 ; Network M550 P"A" ; Set machine name M552 S1 ; enable network and acquire dynamic address via DHCP M587 S"*****" P"******" ; Configure access point. You can delete this line once connected M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X300 Y500 Z400 ; Set axis maxima M564 S0 H0 ; Allow axis move without home and outside boundries ; Drives M569 P0 S1 ; AXIS X M569 P1 S1 ; AXIS Y M569 P2 S1 ; Z LAFT M569 P3 S1 ; FEEDER M569 P4 S1 ; Z RIGHT M569 P5 S1 ; printhead M569 P6 S0 ; FEEDER M569 P7 S0 ; printhead M569 P8 S1 ; printhead M584 X0 Y1 Z2:4 E3:5:6:7:8 ; Use E1 for Z axis M350 X32 Y32 Z16:16 E16:16:16:16:16 I1 ; Configure microstepping with interpolation M92 X157.63 Y158.96 Z400:400 E115:320:115:305:320 ; Set steps per mm for extruders M566 X1200 Y700 Z24:24 E800:800:800:800:800 ; Set maximum instantaneous speed changes (mm/min) M203 X30000 Y30000 Z600:600 E15000:15000:15000:15000:15000 ; Set maximum speeds (mm/min) M201 X500 Y400 Z100:100 E600:600:600:600:600 ; Set accelerations (mm/s^2) M906 X800 Y800 Z800:800 E2500:1200:2500:1050:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ף ; Endstops M574 Y S1 P"ystop" ; Y min active high endstop switch M574 X2 S1 P"xstop" ; X min active high endstop switch ;M574 Z1 S1 P"zstop" ; Z min active high endstop switch ; Tools M563 P0 D0:1 S"A" ;Define tool 0 M563 P1 D2:3 S"B" ;Define tool 1 M563 P2 D0:1 S"C" ;Define tool 2 M563 P3 D0:2 S"D" ;Define tool 3 M563 P4 D4 S"E" ;Define tool 4 M563 P5 D0:1 S"F" ;Define tool 5 M563 P6 D0:1:3:4 S"G" ;Define tool 6 M563 P7 D1 S"H" ;Define tool 2 M567 P0 E3:1 ;MIXING RATIO tool 0 M567 P1 E1.5:3 ;MIXING RATIO tool 1 M567 P2 E1.5:3 ;MIXING RATIO tool 2 M567 P3 E1:1 ;MIXING RATIO tool 3 M567 P5 E0.4:1 ;MIXING RATIO tool 5 M567 P6 E1.5:3:3:3 ;MIXING RATIO tool 6 ;M567 P7 E1.5:3 ;MIXING RATIO tool 7 G10 P0 ;Set tool 0 axis offsets G10 P1 X-207.5 Y5 ;Set tool 1 axis offsets G10 P2 X-33 Y6 ;Set tool 2 axis offsets G10 P4 X-108 y-16 ;Set tool 4 axis offsets ;M308 S0 P"spi.cs0" Y"rtdmax31865" A"temp1" ; ;M308 S1 P"spi.cs1" Y"rtdmax31865" A"temp2" ; ;M308 S2 P"spi.cs2" Y"rtdmax31865" A"temp3" ; ; Z-Probe M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed ; Heaters ; Fans ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss ;m605 s1;
M915 R0 ; stall detection
i started to get warnings about some drivers
" short to ground"
"phase disconnected"
nothing was changed in hardware system and config file wasnt changed but still after a while some drivers became fault.board supplier: E3D
and date of purchase: 2020-06-03is there a way to fix those warnings.
part of the driver already not working.
is it happen to someone before?
what should i do? contact supplier?
tnx -
What exactly leads to an error message coming up?
What is the exact error message?M350 X32 Y32 Z16:16 E16:16:16:16:16 I1 ; Configure microstepping with interpolation M92 X157.63 Y158.96 Z400:400 E115:320:115:305:320 ; Set steps per mm for extruders M566 X1200 Y700 Z24:24 E800:800:800:800:800 ; Set maximum instantaneous speed changes (mm/min) M203 X30000 Y30000 Z600:600 E15000:15000:15000:15000:15000 ; Set maximum speeds (mm/min) M201 X500 Y400 Z100:100 E600:600:600:600:600 ; Set accelerations (mm/s^2) M906 X800 Y800 Z800:800 E2500:1200:2500:1050:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30
In this block you have 2 values defined for the Z axis. This is not supported. For each of those cases remove the second value for Z.
Z400:400 should just be Z400.
@moo16 said in Duet wi fi + duex 5 - drivers faults:
Please update your firmware as well. First upload this zip file as is for 3.0 to the /sys folder in DWC and then again for 3.1.1.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
Once you have those things fixed, please post the results of M122
s
