Add Additional Temperature Readings in DWC RRF 3.01+
I am adding additional thermistors to the 3 that I am already using with the extrusion heaters and bed heaters on a Duet 2 WiFi and RRF 3.01. ow do I get those readings on the DWC if I won;t be using any of the heaters? I have been using M308 and M563 commands so far, and they don't seem to be working. I only get the display of the thermistors names but no readings so far.
Thanks in advance,
Diego -
Can you post your config.g?
Also update to firmware 3.1.1 and DWC 3.1.1
There is no reference of temperature sensors for M563
M308 S0 P"exp.thermistor3" Y"thermistor" T100000 B3950 ; M308 S1 P"exp.thermistor4" Y"thermistor" T100000 B3950 ; M308 S2 P"exp.thermistor5" Y"thermistor" T100000 B3950 ;
![alt text](
image url)
@dieguito said in Add Additional Temperature Readings in DWC RRF 3.01+:
exp.thermistor4
are you using a Duex or just the expansion port? i believe there is a resistor "missing" if you're not using a Duex.
Send M115 to verify that you have 3.1.1 firmware installed. Your screen shot shows the web interface has been updated, but not the firmware.
@Phaedrux It looks like the only way for them show up on the dwc is through a "virtual" heater? not ideal, but at least it shows me the readings
