Building a DIY public domain low cost stepper motor analyzer
@bearer said in Building a DIY public domain low cost stepper motor analyzer:
it does. but packing several projects into a single repo doesn't lend itself well to sharing or collaboration
Sorry about that. This is my catch all 'misc' repository. I plan to clean up the stepper analyzer in the next week or two so will also move to an independent repository.
Meanwhile, if you encounter any problem, let me know here. I will monitor this thread more closely.
Flushing the firmware has two parts, flashing the Nextion 3.5" using a micro SD card or the nextion designer with a serial port, and flashing the Teensy 4 which I currently do with the Arduino IDE (need to install the Teensy 4 extensions) but am looking for a simpler way (any suggestions?)
@zapta said in Building a DIY public domain low cost stepper motor analyzer:
platformio? (for the teensy at least)
I copied the stepper analyzer files to a dedicated repository https://github.com/zapta/stepper_analyzer (will delete files from the old repository later).
It also includes a release directory with binaries for the teensy and the nextion 3.5". The teensy firmware can be flashed with a teensy loader (https://www.pjrc.com/teensy/loader.html) and the nextion using its sd card.
It's still rough and I plan to clean it up in the next week or two. Please let me know how it works for you.
Thats awesome, its on my list to try and build one! Thanks for putting this out there man!
The new PCBs arrive and I like how small and simple they are:
I also added a retraction analysis screen. It is cumulative such that retract 10 steps extruder 3 steps, retract 5 steps will show retraction of 12 steps.
The graph moves in real time so the camera didn't capture it well. The little noise at the bottom of the graph are tiny retractions due to pressure advance (0.08).
I plan to commit the changes to github later today.
Have you considered building a small batch of complete units and selling them to us poor souls who would love to get our hands on one?
I'd could be down for crowd sourcing myself one if such a thing were to be a thing.
@fcwilt, I would love to do that because I think the makers' 3D printer market needs a tool like this but I can't do it myself. My hope is that someone can pick it up and provide to the community, this exact design or a lower cost version of it (with a stand alone MCU and a dumb LCD). The license is very liberal, non need to attribute, no need to share code changes, commercial OK, etc.
I just created a documentation page in github. It explains the various functions, how to flash the firmware and a BOM.
I'd be happy to build and test (some) additional boards when I make mine, but despite the BOM being about $50-60 (10 seconds guesstimate) statistically it'd be close to double that after shipping, taxes and fees + another $7 to ship it out again. There is no real need for me to source the teensy and screen which brings the rest down to $10-20 (before shipping, taxes and fees). So my location is probably a bit cost prohibitive even when not making a profit.
@zapta is the SD card required for the nextion to run, or just the programming? I'm still waiting for that aliexpress order ... 176 days is the 2020 shipping highscore:/
@bearer
If you've got a PayPal account I'd buy a unit from you.
@fcwilt i do. i've posted an informal doodle https://doodle.com/poll/hhw2iyirf8fctmn4 where interest could be gauged, but admittedly very skeptical as global shipping is very unreliable these days.
@zapta wanna pick your brain a bit .. why did you go with analog output current sensing and not with one with integrated ADC with spi output? Something like LMP92064 for e.g. comes to mind?
I am now deciding between LMP92064 and ACS70331 + AD7705 and it looks like ACS70331 + AD7705 will go in final product 'cause I need the resolution but since you are using the ADC on the teensy I guess LMP92064 would be easier solution ?! Or you went by the price (LMP92064 is ~3x more expensive locally, I guess it's same everywhere)
Just for programming and should be removed for the Nextion to function. I just updated the documentation to clarify it.
@fcwilt said in Building a DIY public domain low cost stepper motor analyzer:
Just a suggestion. One payment method that worked for me in the past is amazon gift cards. Buying often on amazon, credit is almost like cash, and cards can purchased online at any amount and the gift card number can be sent by email.
I believe that BOM could be reduced well below $20 with a dumb LCD (example below) and a stand alone MCU (vs the Teensy 4.0). All is required is somebody that is proficient with writing firmware and can re implement the UI for the dumb LCD.
https://www.buydisplay.com/serial-spi-3-5-inch-tft-lcd-module-in-320x480-optl-touchscreen-ili9488
Edit: another option is to drop the display and use a USB or Bluetooth attached computer or phone/table for the UI. The voltaic isolation of the current sensors will make it safe for the USB connection. This opens new possibilities such as recording, correlating signals from multiple steppers (e.g. X/Y in core XY), and so on. With a stand alone, non Teensy standalone MCU, this will be a tiny and inexpensive device that can be plugged anywhere. BTW, the Teensy and Nextion consume ~250ma so a battery operation is also feasible. Many great possibilities that wait for the right entrepreneur.
@arhi said in Building a DIY public domain low cost stepper motor analyzer:
The main advantage of the ACS70331 for this application is the voltaic isolation.
The LMP92064 would kind of work for a single stepper coil if it's ok to have the circuit floating with the stepper signal but wouldn't work for two coils since they don't have a common ground.
BTW, you can find it in different current ranges and polarity (directional vs bidirectional) https://www.digikey.com/products/en?FV=-5|62165
I never thought about that approach. I will remember it.
Yes, LMP is not isolated .. I believe there are some isolated ones but ACS70331 + AD7705 is probbly better option anyhow
Between just wanting the one and being the kind of guy that thinks a .csv file is a perfectly acceptable user interface buying the fancy screen makes the most sense to me. For the Teensy I'm thinking put headers on it so less hand assembly and it can be repurposed if needbe.
Its also easier to offer to hand assemble 10 or simple parts than a MCU with supporting parts
I'll help the community as best I can, but I don't I have the ambition or capability to be very entrepreneurial. Still, my hat off to you for your work on this!
edit: Total Nextion noob wasn't sure which display to use but seems the Basic NX4832T035 that i accidentally had on order will do the trick (the Enhanced NX4832K035 will readily compile but the others will either crop or not scale well to/from 480x320)
@fcwilt I just placed another order for the bare pcb's as the first never arrived. Fingers crossed PCBway will deliver:)
