Duet 3 with SBC and 5V fan
Fan Shim ? under the cable
@Carlo said in Duet 3 with SBC and 5V fan:
In general yes, but then my RPI case doesn't fit anymore because the height of the ribbon connector increases. My printer is currently running 24x7 and I just want to avoid printing the case again. Need to finish all the other printer parts.
it also means no heat sinks so increased cooling need when idle?
@bearer
I don't run mine with heat sinks had no issues with temps?
Only covers the cpu so heat sinks can be placed on the other chips -
You can always do what I did.
@madmattco said in Duet 3 with SBC and 5V fan:
product link would be handy for the uninitiated?
@bearer
https://www.amazon.com/gp/product/B07R45W1LN this is the top board
https://www.amazon.com/gp/product/B07MCW4KCM this is the right angle pin adapter
And if you're interested, this is the nvme adapter im using
https://www.amazon.com/gp/product/B07MCW4KCM this is the right angle pin adapterthis one might be interesting for quite a few people here!
(was tempted to get one in order to de-jankify the PoE / Duet mix, but realized it won't fly without extending the 4 PoE pins as well. will have a think, or ask jlcpcb to send something similar:)) -
I am using one of these to power it all.
https://www.amazon.com/gp/product/B07ZQB6S3L
5v feed to the duet3 is also disabled
For what it’s worth the DOSTAR LED connection works to give 5V as someone else already mentioned. I use that to power a pi touch screen.
