Sleep, now I cant see duet
Good morning... So yesterday as I was toying with ending gcode etc I think i wanted to try out the sleep command.
Woke up this morning after a print had finished and cant connect to my duet. Powered it off, back on again, nothing.
Is this normal behavior? Just curious as to why suddenly ive lost wifi access to it.
3.1 fw version , duet wifi board.
thanks -
@dunginhawk said in Sleep, now I cant see duet:
try usb and in general https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
@bearer its all inside a case dangit... lol
@dunginhawk if you have a paneldue you can try running gcode from there to troubleshoot the wifi (M552) but its takes a while to work with the touch keyboard as well.
(consider adding a short panel mounted micro usb extension cable for the future)
