Heater issues with RRF 3.x
OK, updated to RRF 3, few minor issues but got them mostly figured out, but the heaters are being an issue..
heating hot end it over shoots by 5-10º c every time now -Tried doing a PID tune but it fails also as it takes like an hour to get to 140º let alone to 240º
try to heat bed and it gets the "fault, bed heating too slow"
Searched the internet but got no fixes.. any ideas? guessing it something simple I'm missing?
thanks
What firmware version exactly? Should be 3.1.1. Send M115 to verify.
Ideally you shouldn't be using a lower PWM duty cycle for PID tuning. Any specific reason for using P0.4?
What are your heaters and thermistors? What duet board?
Post your config.g
THANKS for the response!
it's 3.1.1 now (was 3.0 at time of post, though no change)- FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
Hot end heater and therm - E3D stock for Hemera
Bed and therm - Fodgertech 12v 300x300x3mm alum/PCB plate with stock therm (honestly the thing heated pretty fast till update)The "P0.4" was just a copy paste thing. redid that, got both the bed and hot end to do a PID tune, but now where to put it? wont do a M500, gives an error. (rather have it in the Config.g anyway), Read that M307 doesn't work anymore? And, even with a PID tune, likely it'll still trip the overly sensitive setting?
Curious?, Why isn't there a simple setting somewhere that you can adjust the duration and rise of temp for thermal protection like in Marlin? How are people getting their beds to heat up with 3.x.x? Can't imagine most beds heat fast enough to avoid this from happening? Guessing there is something I'm missing somewhere?
Config.g included as a file ..LlamaCoreConfig.txt
OK, this seems to have fixed it? not sure if it's really the right way to do it or not? I just replaced the M307 line from the old 2.x.x firmware. did another PID tune and edited the 3 settings...
M307 H0 A68.2 C561.1 D2.6 B0 ;(replaced PID tuned?) PID after RRF3 install
;M307 H0 B0 S1.00 ;(Stock) disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
;M307 H1 B0 S1.00 ;(Stock) disable bang-bang mode for heater and set PWM limit
M307 H1 A472.4 C288.9 D5.0 V12.1 B0. ; (replaced PID tuned) PID tuned after RRF3 install. -
So you've got it PID tuned and it's working properly now?
@Phaedrux seems to be, heaters at least, now all the sudden homing isn't working correct, which I (thought) i'd fixed.. will play later.
