Thermistor Heater n/a
Hi everybody, I bought an already used Duet Wifi and everything works fine except the thermistor of my hotend heater. The thermistor is only working if I upload the config.g file new. If I open the DWC after that again thermistor is showing n/a and I have to upload the config.g file again.
Does anyone already knew this issue? Many thanks in advance for feedback.
That seems very strange. Can you please provide some more information.
What firmware is installed? (send M115 to find out)
What version of DWC is installed? (look in the settings tab)
What are the heater and thermistor? where are they connected?
Please post your config.g as well.
If you send M98 Pconfig.g in the gcode console do you get any error messages? -
I use Firmware version 1.21 and DWC 1.22.6.
I use an e3d v6 with an atc semitec 104gt.
Please find below my config.g
; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 11 2020 22:27:38 GMT+0200 (Central European Summer Time); General preferences
M550 P"Sparkcube Edge" ; set printer name
M667 S1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z1200.00 E370.00 ; set steps per mm
M203 X12000.00 Y12000.00 Z600.00 E3000.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X1300 Y1300 Z320 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X255 Y175 Z300 S0 ; set axis maxima; Endstops
M574 X2 Y1 Z2 S1 ; set active high endstops; Z-Probe
M558 P0 H5 F120 T12000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X5:250 Y5:170 S20 ; define mesh grid; Thermistors
M305 P0 T100000 B3974 R4700; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B4725 C7.060000e-8 R4700; Put your own H and/or L values here to set first nozzle thermistor ADC correction; Heaters
;M305 P0 T10000 B3974 R4700 ; set thermistor + ADC parameters for heater 0
;M305 P1 T10000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
1.21 is quite ancient at this point. I think it would be a good time to try updating to 2.05.1.
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
I will try it. Just to be sure, i have only to download 2.05.1 Duet2CombinedFirmware.bin with 402KB and Upload via DWC?
since you're coming from 1.21 you may need some IAP programming bin files as well, so you may want to update to 2.0 first (and include the IAP files from that release, and then 2.05.
Once you have 2.0 installed you can upload the firmware zip file from 2.05 in its entirety and it should extract and update automatically.
Many thanks for the feedback. I think the update to version 2.0 worked. DWC shows now the hotend temperature.
But now i have a new problem, the heater is off and will not heat.
I am really sure that i have done the wiring correct.
@Phaedrux said in Thermistor Heater n/a:
Heater is e3dv6 and connected to E0 Heater on the board and the thermistor is an genuine atc semitec 104gt connected to E0 thermistor.
M98 PCONFIG.G shows the following:
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
I think its working now, i was too stupid to activate the heater 1 in the DWC
Have you updated all the way to 2.05.1 yet?
Yes, I am Running now 2.05.1.
But now i have a new stupid question. I can maximum choose 235 even though in the config 280 is set as maximum
