Error: Heater 0 fault: temperature rising
Hello all, I just upgraded my duet 2 maestro from firmware 2.0 to 3.1. I used the need reprap on-line configuratior. I finally got everything working except the hot bed, it turns on and I get this error "Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7c/sec". Everything was working great with firmware 2.0, but now I just get this fault. I am not sure what is going on, my hot end works great. Here is the output from my config file.
; Configuration file for Duet Maestro (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 09:32:59 GMT-0500 (Central Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P0 V30 ; Stealthchop2 till about 150 mm/sec
M569 P1 S1 ; physical drive 2 goes forwards
M569 P1 V30 ; Stealthchop2 till about 150 mm/sec
M569 P2 V30 ; Stealthchop2 till about 150 mm/sec
M569 P3 V30 ; Stealthchop2 till about 150 mm/sec
M92 X80.00 Y80.00 Z400.00 E90.00 ; set steps per mm
M203 X300000.00 Y300000.00 Z6000.00 E216000.00 ; set maximum speeds (mm/min)
M201 X800.00 Y800.00 Z15.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X200 Y200 Z200 S0 ; set axis maxima; Endstops
M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:200 Y15:195 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
T0 ; select first tool -
Have you tried PID tuning the bed heater yet?
@Phaedrux said in Error: Heater 0 fault: temperature rising:
PID tuning
Thanks for the input, everything is working now.
