RRF 3 Z home not triggering.
@JoergS5 said in RRF 3 Z home not triggering.:
I don't understand the comment: "only DWC is reporting a 4th sensor that i can never get triggered.", can you make a screenshot please?
0 is tied to my x
1 is my y
2 is either of my inverted Z axis switches
3 is in question.would you suggest i make another post for my last issue?
im trying to make it so that when i run a g32 it will probe the bed and auto level the individual z axis
@JoergS5 yes, it absolutely does work now. it successfully homes now.
Fine, a first success!
Please don't open a new thread, but leave all points here to be discussed (and hopefully solved).
The 4th sensor could be your second Z endstop, but DWC should fuse the two Z endstops together:"Note that DWC and M119 will only show one endstop per axis, but will show the axis endstop as triggered if either switch is triggered. So you can test them by triggering one at a time." in https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Axis_levelling_using_endstops
Please tell me the DWC version or update to the newest and test again. Maybe you have a version of DWC which does not fuse.
Board: Duet WiFi 1.02 or later
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
Duet WiFi Server Version: 1.23Note: You can install updates on the System page.
I don't know which version has which problems. Best would be to update to newest versions before going on. 3.0 is a bit old.
@JoergS5 hmm i figured it was the newest one. where can i find the absolute newest one
The newest RRF release is under
https://github.com/Duet3D/RepRapFirmware/releases
(as of today: 3.1.1) -
setting up the nozzle probe according to this doesnt seem to be working.
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
Connect it between the STP and GND pins of the E0 connector and select mode 4. If it is a normally-closed microswitch, then with version 1.15 or earlier firmware use M574 E0 S1 to select active high trigger level. For normally-open contacts (not recommended), send M574 E0 S0 instead. With 1.16 or later firmware, include parameter I1 in the M558 command if you are using a normally-open switch.
so ive discovered that mode 4 is no longer supported in RRF3 and am advised to use mode 5 or 8 instead,
i have tried both and neither make a difference.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_in_RepRapFirmware_Num_3
"Z probe types 4, 6 and 7 are no longer supported. Instead, use type 5 (filtered digital) or 8 (unfiltered digital) and use the C parameter to specify the input. Note, if your Z probe is connected to the Z endstop input, in RRF 3.0 on Duet 2 boards only (not in RRF 3.01 and later, and not in RRF 3.0 on Duet 3), that input is by default pre-assigned to be used by the Z endstop, so you must free it up first."
ive noticed that when i home my Z axis, i am using my 0.20mm feeler gauge to make sure that my gantry is perfectly trammed with the bed plane.
if i set my carriage to the left most position and drop it down so that the nozzle height is just touching the gauge my z height is being reported at 1.45 how ever on the right side its being reported at 0.95.
when i manually adjust the stepper to make them even and than i rehome, it goes back to exactly the same place.
how do i force either the right side or the left side to stay in line?
edit:
So i just raised the z height to +50 and dropped it back down, the left side is still touching the feeler at 1.45 how ever now the right side is touching at 0.80. it lost 0.15 over 50mm clearly there is an issue with my second z motor and its speeds perhaps -
I'm late to the game. It appears you have two Z end stop sensors.
How are you assuring that when the sensors are triggered the bed is parallel to the gantry?
Currently trying to set this up
in my Config
M671 X-144:144 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E0) of X axis
and this is in my bed
G28 ; home
G30 P0 X-110 Y0 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X110 Y0 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
G29 ; probe the bed and enable compensationbut its not working
also, the g30 is just calling me to manually adjust the zheight instead of using the nozzle as a probe.
@joehsmash said in RRF 3 Z home not triggering.:
Well in the last config.g file you posted I see this:
M558 P0 C"!zstop+!e0stop" B1 X0 Y0 Z0 H2 F60 T6000 ; Set Z probe type to switch
Unless something has changed in firmware v3, the parameter P0 specifies no Z probe.
This would be consistent with the behavior you are seeing.
@fcwilt i agree with you there, so is there no way to use the Z axis endstops as a sudo probe? i know it wont be true leveling but its all i have for now seeing as my IR probe wont work.
i read another post a while back where a guy got it to work, i sent him a message but hes long gone. granted this was on 2. something
@fcwilt ive located the post
While many things are possible in v3 firmware that are not in v2 (which is what I am still using) I cannot imagine how you could do that.
Perhaps DC42 will jump in and address this question.
Just out of curiosity do you have bed leveling thumbscrews or something like them for manually adjusting the bed?
I built a printer not too long ago with three Z motors and a BLTouch Z probe to try automatic bed leveling. While it worked it was more complicated and noisy than my FT5 which used one Z motor and manual bed leveling and didn't work any better.
I re-built it with one Z motor belted to two lead screws on opposite sides of the bed, much like the FT5, and a BLTouch Z probe.
I'm much happier with that arrangement.
Something to consider.
@fcwilt @dc42 has chimed in before to help.
i do not have levelling screws on my bed. its actually held to the y gantry with magnets that are epoxied to the bottom of the glass bed.
one of the future upgrades i have planned is to re design the y gantry supports to allow me to delete the magnets and add in a screw type adjustment.
but with that said, i have manually leveled and used metal shims that tto get all of the magnets to within 0.01 so the bed it self is level, just the zmotors arent and im not sure how to get the one driver for E0motor to come up or down.
i also just ordered a BLtouch, how ever with the design of my xcarriage its going to be a challenge getting that set up. but again i will likely need to reprint the carriage to get it to work as i want.
This applies to you
https://forum.duet3d.com/topic/16766/offset-for-dual-y-endstop/3
obviously you apply it to Z rather than Y. But you can adjust one of them (probably the one that reads 1.45) down by ~-0.65 so they are both at the same height.
