Z-probe not moving down to touch the bed
Hi guys,
I am new here and looking forward to contribute.
I have an FLSun QQ-S Pro and installed a DUET 2 ethernet this week. Currently I have 2 issues. Homing & Probing
Homing;
When I press "home all axis" and the printer has to move a larger distance. It stops homing after the first endstop is triggered. After I press it a second time it homes on all Endstops. Suggestions?
Probing;
I have the Z-probe connected and everything works almost as expected. Except for the triggering move. The probe moves across the bed without moving downward to actually click the trigger. Suggestions?My config.g
*; Configuration file for Duet WiFi (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri May 29 2020 13:42:29 GMT+0200 (Midden-Europese zomertijd); General preferences
M550 P"QQ-S PRO" ; set printer name
M665 R140.8 L280 B130 H450 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; set active high endstops; Z-Probe
M558 P4 H0 F120 T3000 I1 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z16.200 ; set Z probe trigger value, offset and trigger height
M557 R120 S20 ; define mesh grid; Heaters
M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
T0 ; select first tool*My Bed.g
*; bed.g
; called to perform automatic delta calibration via G32
G28 ; home all towers
; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
G30 P0 X0 Y84.9 H-5 Z-99999
G30 P1 X73.53 Y-42.45 H0 Z-99999
G30 P2 X-73.53 Y-42.45 H-10 Z-99999
G30 P3 X0 Y42.4 H0 Z-99999
G30 P4 X36.72 Y-21.2 H-10 Z-99999
G30 P5 X-36.72 Y-21.2 H0 Z-99999
G30 P6 X0 Y0 H0 Z-99999 S6
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
Please post your homedelta.g file.
What firmware version are you using?
What type of probe is it?
What do you have in your slicer start gcode?
@Phaedrux Thanks for your reply!
; homedelta.g
; called to home all towers on a delta printer
G91 ; relative positioning
G1 H1 X450 Y450 Z450 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centreWhat firmware version are you using?
It is a digital switch that comes standard with the printer. So i don't level before every print as the bed on my printer is fixed.
Not there yet, I just put in the board and trying to get it to work. I haven't printed anyhting yet. -
@Brouwi
does it flash as triggered in DWC dashboard then move ? as you may need to invert the switch
Also your dive height is 0 set it to 25
