Piezio do and ao
I have a Triangle Labs piezio board and sensor in stock I would like to try. The sensor sits on the hot end nozzle. The board has ao do and and Vcc pins. If I use digital output would I use an endstop header? As opposed to the z probe connector?
You can still use the z probe connector and use mode 8 for M558
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mode_Num_8
@Phaedrux Thanks
BTW I ditched the lead screws and am now using belts. I am using stuff in stock so two standard 6mm GT2 belts are being used. I have X and U synced up. Looks like I will have 1.2 meters x .5 meters printable area; with a z height of about 250mm.
Any ideas for the "final ideal" belt?
I would like to go with a 1mm or 1.2mm nozzle. Any ideas in terms of hot ends? Do I want to be using 1.75 or 2.85.. I have some bondtech 1.75mm in stock.
@wepollock Might be better to start a new thread on a more appropriate category with a descriptive title to get more eyes on your questions.
