[HELP] How to use DueUI without a Duet using chrome
@gtj0 I'm using duet 2 ethernet connected via cable and the url you gave me works...
I assume I have to give that url but with the json file's path -
@gtj0 it works, I don't know if it's because you changed the file name with dueui_config_default_standalone.json that didn't work
@Dario02 Ah OK. You can use the DuetWebControl to see the files on the Duet's SD Card.
@gtj0 yay, now it's working fine, I have to "study" how to use elements etc
@gtj0 is there a way to modify the config.json without removing the sd card?
@Dario02 Sure. Use the DuetWebControl and go to "File Management, System". You can upload files and even edit the config.json file right from there.
@Dario02 Oh don't forget, the file doesn't actually have to be on the Duet. You can have it anywhere as I described above.
@gtj0 ehm... how should I use dwc if I can't see it?? I just received my duet and I'm not well informed... My last question is "how can I setup my DUEUI for a 7" rpi lcd?
@gtj0 I mean that if I search 192.168.1.118 I only see a blank page... before install dueui I was able to see the dwc page
@Dario02 said in [HELP] How to use DueUI without a Duet using chrome:
If 192.168.1.118 is the IP address of your Duet, then just go to http://192.168.1.118/
That the default user interface that ships with all Duets.My last question is "how can I setup my DUEUI for a 7" rpi lcd?
You'll need to run a browser on the Pi.
@gtj0 so is the page responsive?? Cause I tried with your apk from my smartphone and I see a page that doesn't fit my screen size
Oh. Something got messed up then. The install of DueUI should NOT have touched the existing DWC installation. Let me check on something.
No. It renders however you designed it and it depends on the browser and screen resolution.
@gtj0 If I search 192.168.1.118 now I see a blank page, if I use ctrl+u I'm able to see that the html only shows dueui.startup() or something similar
@gtj0 ok so I have to make a page for my 7 inch, ok I don't know how but I'll try
@gtj0 I searched http://192.168.1.118/reprap.htm and now it displays the dwc... ok
@gtj0 I'm tired now it's midnight where I live, have a nice day, thank you!
@Dario02 That was my fault. I accidentally included a file in the zip that shouldn't have been there. Since you can get to the DWC now using reprap.htm, you can re-upload the DWC from this zip and http://192.168.1.118/ will work again.
https://github.com/chrishamm/DuetWebControl/releases/download/2.1.7/DuetWebControl-SD.zip
@gtj0 I'll try tomorrow and let you know, thanks
@gtj0 it works, is there a complete wiki or documentation for dynamic value and other stuff that are not documented on github ?
@gtj0 I tried your examples written in the wiki and most of them didn't work
