paneldue 7i does not turn on
by connecting the pc's usb cable, the voltage reaches between 4.54 and 4.56v.
on webcontrol it oscillates between 0.4 and 0.5v
the paneldue with the pc cable turns on very well
the card came to me from filafarm germany, don't tell me I have to send it back
@Leblond You measure 4.57V with VIN and USB? If the Duet is powered by VIN, disconnect USB. That's what killed your last Duet!
Or does the voltage drop when you connect the PanelDue?
Can you show the 4-wire cable connected to the PanelDue?Ian
@droftarts I didn't connect the card to the network, I didn't want to end the last time I was very careful if that's why, the first photo I sent you was connected to the electrical network, instead the second one was connected to the USB port of the
I was very careful and I followed the pattern by thread and by sign
as you can see the cables are assembled well
nothing has broken the card
I was making a little reflection, admitted and not granted that the card went to be blessed, at least the 3.3 LEDs should not turn on and not even the wifi module
but everything works, but I don't understand the voltage drop on the 5v
of fused cards I just need one after what I spent to get a new one, I repeat it I didn't make the mistake I made with the last one, I even put on an antistatic bracelet in handling both the card and the paneldue, I have took all necessary precautions
I tried to see if I have 3.3v and it is there
likely to be defective?
@Leblond No, I think your cable is wired incorrectly. See mine, it works (PanelDue 5i):
@droftarts Are you telling me I melted it?
