Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3
@Phaedrux
This is the last config file matching all the other files you see above.
I promise not to touch anything else until you return to me.; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 18 2020 19:50:27 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Daniel Ender 5" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z800.00 E409.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z50.00 E5000.00 ; set accelerations (mm/s^2)
M208 X220 Y220 Z300 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-45 Y3 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:160 Y15:200 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
@Daniel said in Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3:
Also we should test that your z axis steps per mm is correct at 800. In addition to the test above in the console, send the following making sure that your bed is safely away from your nozzle.
G92 Z0
G91
G1 Z10This should move the bed 10mm down away from the nozzle. If it does anything else, kill the power.
Measure how far it actually moves.
@Phaedrux
From me standing in front of the printerG1 X-10 moved right
G1 Y-10 moved back -
Ok, now what happens if you test the endstops as described here: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39#s145
The G1 Z10 moved the bed exactly 10.27mm downwards
Before I moved anything, with the head in the center of the bed (approx) the endstops look like this
What it is basically wrong. They are opened.
@Phaedrux
When I close the circuit by pushing the trigger, both Circuits change to "No"This is really confusing, Triggered means closed or open?
@Phaedrux
What would be the right switch to choose between all this?
xstop,
Xstop inverted
xstop pull up
xstop inverted pull upor should I changed in the next page?
You also said my logic was inverted 180 degrees. How should I look at all this (I am left handed and brain washed)
I believe we should choose in this last screen, Active low, High end to reverse the screen and finally change the direction of the motors by selecting reverse direction in X and Y.
What say you? I am going to give it a try....
Then - X would be with the motor moving to the left and -Y would be with the motor moving towards the front....and it will match the deviation of the bltouch probe in -x (45 and 3) +y -
Sorry for the delay.
For the endstops we can change them in config.g
M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
Change the S1 to S2 for both. Then test the endstops again.
Doing high end for both would give you the 180 degree rotation we discussed earlier.
This is normally how the coordinate system would appear when looking at your printer from the front. The homing location is irrelevant. Instead of homing to 0 it would home to 280 or whatever.
@Phaedrux
Ok, I tried changing the configuration without success on the RRF to try to get those S2 values to show. I finally changed it on the config and we are like this; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 18 2020 22:46:43 GMT-0400 (Eastern Daylight Time); General preferences
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z779.00 E409.00 ; set steps per mm
M203 X18000.00 Y18000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min)
M574 X2 S2 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S2 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M143 H1 S300 ; set temperature limit for heater 1 to 300C
M563 P0 S"E3D V6 Nozzle X" D0 H1 F0 ; define tool 0
However in our machine specific configuration, the end stops continue to show like this when the head is in the middle of the bed....
Is this right?
M574 Y2 S2 P"ystop" ; configure active-high endstop for high end on Y via pin ystopDid you get a full new config set from the configurator? At this point it may be easier (for me anyway) if you stick with one config and we manually alter it. If you keep changing things in the configurator it makes it a lot harder to notice everything that's changed.
For instance the config now has Y2 X2, which would be the high end of travel. That's fine, it would be the more traditional way of doing it.
Is this right?
Can you post a photo of the endstops and how you have them wired?
@Phaedrux
Sorry Phaedrux,
I was trying to get this to show more like your logic, so the alignment on the Bltouch later comes easier to you.
Let me take the pictures and return to you. -
I have oriented the colors to match the letters for Signal Ground and Voltage in the printer run end sensor and in the motherboard. Double Checked.
The original wire on the Ender 5 is a 2 wire cable. Just connected in both ends of the run end sensor = S and V
The instructions on the Duet 2 page mention the 2 wires from the ender connector should be connected on the outer two of the three connectors on the motherboard (leave the center empty). That would mean that S and V from the ender should be connected to S and G in the motherboard.
That did not seem right to me, so I preferred to keep the convention matched on both circuits and made my own cable.Phaedrux, Whatever they pay you to do this job (if any) is too little.... please let me know how can I compensate all this help and assistance. Best regards. Daniel
Ok, those 3 wire endstops might need to be wired a little differently, I'm not sure because I'm having a hard time orienting your photo against the wiring diagram.
But hopefully based on this info and the wiring diagram you can verify it.
https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
