Help needed to remap fan1
I had a wire break on my hot end fan and the wires shorted and fan1 port is no longer working. Can I use fan2 for the hot end and how?
Duet2 maestro and firmware v3
In advance thank you
S. Rolin -
There should be a line in your config.g looking something like:
you can change "fan1" to "fan2" and it will use that connector instead.
@bondus thank you I will try that.
@bondus That did not work, did i miss somthing?
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F1 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency
G10 P0 R0 S0 -
@S-Rolin said in Help needed to remap fan1:
Did you also move the fan port for the hotend fan to Fan2 port?
Yes i did, mabye it is blow to
Have you checked the fan fuse?
Does the fan work when connected to the always on fan port? -
@Phaedrux yes it does, that what i've done to keep the printer running. where would i find the fan fuse?
sorry for alle the questions.
/Soren
Sorry, I see now that you're using a Duet Maestro, so no replaceable fan fuse.
Since this is the hotend fan, you could still use the always on fan port. If fan port 1 and 2 are no longer working.
Actually. the fan 2 block has it's own voltage select jumper, how is it set? Perhaps it's not set properly and that's why your Fan2 port isn't working as expected.
https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram
