Extrusion Control on Web Console
I've reconfigured a new Duet 2 Ethernet today. On the previous Maestro I could extrude filament on the web console. I've loaded the new RRF 3 that was release today, as well as the new web console. think it is 2.1?? Any case.. The extrusion control is disable. Normally when temp was reached it went active.. I think im missing something. How does the load filament work - What is the purpose?
When you updated to RRF3 did you also make the needed changes to your config.g?
Given your adventure in your other thread I would perhaps caution you to stick with the 2.05.1 release for the time being unless you're up for some beta testing and troubleshooting with RRF3.
I'm sure my config.g is fine for v3. I did do the changes
I'm having the same issue since I updated from RRF 3.0 to 3.01-RC6 and to Web Control 2.1.0
@wcj97 I think that may have been fixed in DWC 2.1.1
works fine in DWC 2.1.1
It has been fixed. Thanx a mil.
