DuetLapse available for Alpha testing
@gtj0 said in DuetLapse available for Alpha testing:
Teslong USB "Endoscope". It only supports MJPEG as a palette and I just noticed that you've got YUYV hard coded on the fswebcam command line. Maybe don't specify '-p' and let it default?
I think I did that and it required it for some reason. I will try a couple of different things to get it as automatic as possible.
Thanks for sharing I. I'll try installing this in whilst in lockdown.
I had an idea to use a pi remotely to control RGB LEDs based on the printer status. (eg red = heating, white = printing, green = finished)
I might try and learn how to do this based on your code/logic -
Would it be possible to use an old iphone as the camera?
I noticed that if you have a password set (M551 P"Password") then DuetLapse can't connect to the Duet.
Attempting to connect to printer at 192.168.1.104 http://192.168.1.104 does not appear to be a RRF2 or RRF3 printer Device at 192.168.1.104 either did not respond or is not a Duet V2 or V3 printer.
Do you have any plans to add this feature in the future?
Cheers -
@Danal said in DuetLapse available for Alpha testing:
fswebcam doesn't require it at least for my camera. It figured out MJPEG by itself. Maybe it's an issue if the camera supports more than 1 palette. You could check for the existence of ~/.fswebcam and if it's there, add a
-c ~/.fswebcam
to the options. This way a user can put whatever options they want in it.Once I changed the palette, it worked great!
@kingfisher said in DuetLapse available for Alpha testing:
I might try and learn how to do this based on your code/logicThe "interface" is in a separate library, for just that reason.
@tekkydave said in DuetLapse available for Alpha testing:
CheersI didn't but based on your feedback, I will look into it.
@UnderDoneSushi said in DuetLapse available for Alpha testing:
Yes, if it runs software that will allow a still image to be retrieved via a know URL.
HA! Just discovered another reason to use a config file if it exists... To turn off things like auto-focus.
Excellent point.
Found a solution to an issue I was having using DuetLapse with MotionEye.
I have a raspicam which is connected to a Pi3B running Motioneye.
MotionEye will allow a single image to retrieved at a URL similar to:
http://192.168.1.106:8765/picture/1/current/?_username=admin&_signature=b75e2c8efb0c0694a7a4ac1f48037f90566fbead
Using this URL with DuetLapse gives this error every time it tries to get an image
Capturing frame 0 at X65.74 Y47.41 Z0.30 http://192.168.1.106:8765/picture/1/current/?_username=admin: 2020-04-07 15:10:57 ERROR 403: Forbidden.
So I amended the following line in the onePhoto() function in DuetLapse.py
cmd = 'wget --auth-no-challenge -nv -O '+fn+' '+weburl
to
cmd = 'wget --auth-no-challenge -nv -O '+fn+' "'+weburl+'"'
to put quotes around the url. This seems to fix the problem
THANK YOU
I will update
Another tip if you want to play around with DuetLapse without having to set a print going.
Temporarily changeif ('processing' in status):
to
#if ('processing' in status): if ('M' in status): # detect simulating instead of processing
This will make DuetLapse think the Duet is printing when it is simulating. Remember to change it back later
Maybe a -dry-run option can be added to do this in future?
I've just been starting a print, and then pause/canceling it.
Of course, it can do whatever we all agree to... and can code... and dry run is dead simple. I would note that it really only applies to -seconds. A dry run with any kind of -detect is never going to detect anything.
It detects layer changes when running a simulation but, as you say, since nothing is physically moving the video is going to be a bit boring. Useful if you are testing options or trying simple code changes though. I know squat about python so I need all the help I can get. I do find your code very easy to follow though
Thank you. I try to balance being "python-esq" with being readable. For me if nought else.
How about having the "detect printing" detect BOTH processing and simulation? Since we control if the script is running, I see very little downside to this.
That would be the simplest solution I think.
Keep the ideas coming!
In my customised build of Raspbian with duetpi I created a timelapse.desktop entry so that I can access your program from my start menu.
By default I set it to take a picture upon Z movement.
So now, when I start a print and the printer is ready all I have to do is click on the program entry in the start menu.Thank you again danal for giving us this great program.
I've set it up and it works
I did get an error on a small print doing a quick test though
The error was "requests.exceptions.ConnectionError:('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))"
My guess (Although I'm not a Python expert) is that the pi couldn't keep up saving the images as the layers were only taking 20sec (And its an old V2 pi)
@kingfisher
I actually think it might be my Duet wifi board causing an error. I've also got a duet maestro and running the same python settings on the maestro IP address hasn't resulted in the "('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))" error
