Not Homing correctly At all. and nozzle issues
Have you PID tuned the heaters?
Ok thanks, I will look into it.
@bearer So I have checked all components with a voltmeter resistance looks good and also I took the hot end block and the thermistor plugged it in back to the original board and it worked fine. The current thermistor connector is plugged into " E0" on Duet 2Meastro. I think its a time issue, because of the error message says that the heating fault on heater 1 temperature rising much slower then 1.7C. I'm new to duet 3d board and I don't know how to tune PID heaters if you have some tips that will be really helpful. but I did view the documentation and I added few codes to my config.g file I post it now.
; Configuration file for Duet Maestro (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 06 2020 01:48:35 GMT-0500 (Central Daylight Time); General preferences
M550 P"Ender5Plus" ; set printer name; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z800.00 E98.00 ; set steps per mm
M566 X480.00 Y480.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z600.00 E3000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X940 Y960 Z940 E940 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 S1 ; set active low and disabled endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M558 P9 H2 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z2 ; set Z probe trigger value, offset and trigger height
M557 X5:350 Y5:350 S50 ; define mesh grid; Heaters
M305 P0 T98801 B4138 R2200 ; set thermistor + ADC parameters for heater 0
M305 P1 T98801 B4138 R2200 ; set thermistor + ADC parameters for heater 1M305 H1 A199.0 C962.6 D4.5 V24.4 B0 ;
M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
T0 ; select first toolPlease share your knowledge. Thanks
@moe-adams9093 said in Not Homing correctly At all. and nozzle issues:
pardon, I assumed that was done.
look at M303
https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning -
@Phaedrux can you please share how to tune the heater? thanks
@bearer thank you
when I run the command M303 H1 S240 it will fail tunning error message " tunning canceled because of target temp didn't reach. same thing when I run the command M303 by itself.
make sure your 'part cooling' fan is off
Also you can use this command before the M303
M307 H1 D60
then
M303 H1 S240HTH
Paul -
@PaulHew said in Not Homing correctly At all. and nozzle issues:
M303 H1 S240
Thank you, Paul, still the same issue. very slow to raise temp and it stops at 135c
either the thermistor is reporting the wrong temperature
or your heater is for the wrong voltage and you're effectively getting a fraction of the wattage you expect
or there is alot of losses in your wiring
or leprechauns; idk? -
@moe-adams9093 M122 Please.
FYI if you click the button that looks like </>, just above, you can paste your text in there.
iehttps://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
Makes it easier to read!
Also, might worth checking the hotend connections, make sure the ferrules are tight. -
Can you post a photo of the hotend?
Is there something in direct physical contact with the heat block?
Is the fan blowing directly on the block without a silicone sock?
Perhaps the Ender 5 Plus is using a different thermistor than other creality hotends and your thermistor values are completely off. -
@Phaedrux hello can you please help me solve this issue so my ender 5 plus has 2 Zmotors and when I run G32 it doesn't compensate or level the bed very well it still off from corner to corner so I found that I need to set an independent Zmotors to get auto bed leveling up and running I connected first Z motor LeftSide to Z-drive and the second one right side to E1 I spent days reading the duet form but it's not working for me or I have no clue what I'm doing, if you please point me in the right direction that would be highly appreciated
here's my config.g file
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 30 2020 23:57:45 GMT-0500 (Central Daylight Time); General preferences
M92 X80.00 Y80.00 Z800.00 E96.00 ; set steps per mm
M906 X960 Y980 Z960 E960 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X365 Y365 Z415 S0 ; set axis maxima; Endstops
M141 H2 ;Assign chamber heater to heater 2
M307 H2 A11 C99000 D2000 B1 ; chamber heater operates in bang-bang mode
M305 P2 T10000 B3988 C0 R2200 ; Set thermistor + ADC parameters for bed
M143 H2 S80 ; set temperature limit for heater 2 to 80C
M143 H0 S130 ; set temperature limit for heater 0 to 130C
M143 H1 S300 ; set temperature limit for heater 1 to 300C; Fans
M106 P0 S0.2 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S0.2 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
bed file
bed.g
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 30 2020 23:57:44 GMT-0500 (Central Daylight Time)
G29 ; probe the bed and enable compensation
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri May 01 2020 00:50:10 GMT-0500 (Central Daylight Time)
G91 ; relative positioning
G1 H2 Z2 F6000 ; lift Z relative to current position
G90 ; absolute positioning
G1 X5 Y5 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z2 F100 ; lift Z relative to current position
;G90 ; absolute positioning
so when I added this code to config.g file
M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200it didnt work right at all
please help if you can thank you
M584 X0 Y1 Z2 E3 ; set drive mappingYou're going to need to define drive 4 for use as a second Z axis in config.g and change your bed.g to do the probing for the leveling adjustment.
; Drives M569 P0 S1 ; physical drive 0 goes forwards (X axis) M569 P1 S1 ; physical drive 1 goes forwards (Y axis) M569 P2 S0 ; physical drive 2 goes backwards (Z1 axis) M569 P3 S0 ; physical drive 3 goes backwards (E axis) M569 P4 S0 ; physical drive 4 goes backwards (Z2 axis) M584 X0 Y1 Z2:4 E3 ; set drive mapping M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
For the points in M671 you need to find the coordinates of your own bed to measure, you can't just use the example points.
You will connect one Z motor to the Z1 (drive 2), put the jumpers back in the second port. Then connect the other Z motor to the E1 (drive 4)
For bed.g you'll also have to find the points to probe with G30
G28 ; home M401 ; deploy Z probe (omit if using bltouch) G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors M402 ; retract probe (omit if using bltouch)
The G30 P1 will likely be further to the right on your larger bed so adjust the CX position accordingly.
Thank you very much for all your help. I will make these adjustments tomorrow, but how can I find points in M671 coordinates of my own bed measuring, is their sort of documentation can explain how to find the coordinate positions of my bed. thank you again
You just need to choose a point close to the lead screw but still on the bed and both need to be in line on the Y axis.
@Phaedrux said in Not Homing correctly At all. and nozzle issues:
THANK YOU. it worked and I found my correct bed coordinate points. do I have to change any config for my BLtouch current settings are
Z-Probe
I have version 3 -
The dive height is a little low. It should be at least a mm more than the trigger height. Try M558 H3
Also change G31 P500 to G31 P25
Have you calibrated our probe and measured the offsets yet?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
so I have adjusted all the settings accordingly here's a photo of the hight map
so I don't if that's ok or it should be 0 all the way I tried to print a file 340 x 340 and it looks like it's not adjusting probably. here's my updated file config.g
M671 X0:285 Y0:180 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
M558 P9 H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X0 Y0 Z1.758 ; set Z probe trigger value, offset and trigger height
M557 X5:335 Y5:335 S20 ; define mesh grid; Heaters
M106 P0 S0.5 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S0.5 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
T0 ; select first tooland file bed.g
; bed.gG28 ; home
G30 P0 X0 Y180 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X285 Y180 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
M402 ; retract probe (omit if using bltouch)G29 S0
G29 S1I don't know if i have to enable some settings to run hight map while it prints maybe from slicer or from DWC. thank you for all your help
when I run G32 here's the message I get
does that meat its successfully calibrated.
