DuetLapse available for Alpha testing
@zapta said in DuetLapse available for Alpha testing:
@Danal said in DuetLapse available for Alpha testing:
Not a bad idea. I will add that to the "to do" list.
While you do it you can add other visual indicators such as Z height, and filament used.
Keep the ideas coming!
What camera? What command did you issue to start the script?
Morning Danal
I used ./DuetLapse.py -camera pi -duet 192.168.0.7 -
Using -q 40 with the other TL program my filesizes are ...
This is the line it used.raspistill -bm -q 40 -w 640 -h 480 -o $snapshot && curl -X POST http://localhost:8000/snapshot -d '{"name":"'$snapshot'"}'
These are the sizes of the files using DuetLapse
I was getting 'malloc' errors with the other program and it would fail when running the FFMPEG but when I dropped the filesize using the -q it worked. Do not know if the 640x480 had a part in it also.
I can try if it helps you.As I previously mentioned, I am not a Linux / Python guru, just trying to help and fix things myself and also contribute.
Regards,
Paul -
Absolutely brilliant. It works a treat.
Fantastic work! -
@PaulHew You can add the -q 25 (or whatever you wish to try), just put it before the -o. Or, more correctly, not between the -o and the filename.
At this moment, none of my Pi cameras can reach to see a printer. Ribbon too short. I have some longer ribbon, and an Arducam, on the way. Amazon keeps moving the date (which I totally understand). I'll be able to fine tune this more when I receive that stuff.
Meanwhile, keep the specifics coming! (And, you are a lot more of a Guru than you think)
Just about to try it but noticed that it seems to be opening and closing the unix socket twice a second. Not usually an issue except I run the DCS with debug logging so it's kinda distracting. Any chance of just keeping the socket open or better yet, just getting the model updates as they happen?
Getting
# python3 ./DuetLapse.py -camera usb -duet 127.0.0.1 -seconds 5 -detect none Attempting to connect to printer at 127.0.0.1 Connected to a Duet V3 printer at http://127.0.0.1 ################################## # Options in force for this run: # # camera = usb # # printer = 127.0.0.1 # # seconds = 5.0 # # detect = none # # pause = no # # movehead = 0.00 0.00 # ################################## Waiting for print to start on printer 127.0.0.1 Print start sensed. End of print will be sensed, and frames will be converted into video. Capturing frame 0 after 1586032541.73 seconds elapsed. Unable to find a compatible palette format. Capturing frame 1 after 5.01 seconds elapsed. Unable to find a compatible palette format.
Nothing written to /tmp/DuetLapse.
Any ideas?
Which USB camera?
@gtj0 said in DuetLapse available for Alpha testing:
It doesn't touch the unix socket. It is opening and closing a websocket connection, and not persisting it. This was a design choice in startup to not track state. I will look into persisting that connection.
Danal, here is an idea, not necessary specific for this timelapse app, but since you know how to monitor the duet during printing and generate visualization, would be interesting to have something that plot the different time left estimations that the Duet provides.
Think of an x/y graph. X is print time from 0 to total print time T. Y is the time left for completion. The ideal reporting is a straight line from (0,T) to (T,0). And then you can sample the duet and plot the time left graphs by the various methods the Duet uses.
The output can be an actual graph or a csv file that can be plotted with a spreadsheet and the likes.
Which USB camera?
Teslong USB "Endoscope". It only supports MJPEG as a palette and I just noticed that you've got YUYV hard coded on the fswebcam command line. Maybe don't specify '-p' and let it default?
Ah yeah, the websocket will result in the same messages. It's not critical so don't spend all that much time on it.
I think I did that and it required it for some reason. I will try a couple of different things to get it as automatic as possible.
Thanks for sharing I. I'll try installing this in whilst in lockdown.
I had an idea to use a pi remotely to control RGB LEDs based on the printer status. (eg red = heating, white = printing, green = finished)
I might try and learn how to do this based on your code/logic -
Would it be possible to use an old iphone as the camera?
I noticed that if you have a password set (M551 P"Password") then DuetLapse can't connect to the Duet.
Attempting to connect to printer at 192.168.1.104 http://192.168.1.104 does not appear to be a RRF2 or RRF3 printer Device at 192.168.1.104 either did not respond or is not a Duet V2 or V3 printer.
Do you have any plans to add this feature in the future?
Cheers -
fswebcam doesn't require it at least for my camera. It figured out MJPEG by itself. Maybe it's an issue if the camera supports more than 1 palette. You could check for the existence of ~/.fswebcam and if it's there, add a
-c ~/.fswebcam
to the options. This way a user can put whatever options they want in it.Once I changed the palette, it worked great!
@kingfisher said in DuetLapse available for Alpha testing:
I might try and learn how to do this based on your code/logicThe "interface" is in a separate library, for just that reason.
@tekkydave said in DuetLapse available for Alpha testing:
CheersI didn't but based on your feedback, I will look into it.
@UnderDoneSushi said in DuetLapse available for Alpha testing:
Yes, if it runs software that will allow a still image to be retrieved via a know URL.
HA! Just discovered another reason to use a config file if it exists... To turn off things like auto-focus.
