U axis don't print
OK, I think I've got it. Try this:
M584 X0 Y1:2 U5 Z6:7:8:9 E3:4 ; Mapping drivers M563 P0 D0 H1 F1 S"X" ; define tool X M563 P1 D1 H2 X3 F4 S"U" ; define tool U M563 P2 D0:1 H1:2 X0:3 F1:4 S"XU" ; define tool X+U copy mode M563 P3 D0:1 H1:2 X0:3 F1:4 S"XU" ; define tool X+U mirror mode
The "3" seems to be the logical number of the axis to be mapped. That is X=0,Y=1, Z=2,U=3, etc. And the lines that map the copy or mirro do seem to need both the 'base' axis and the 'extra' axis.
Let me know if this works.
@Danal said in U axis don't print:
I'm running an IDEX machine (albeit on RRF2) but this should do the trick.
X3 instead of X5 is correct - X (0), Y (1), Z (2), U(3)
I have not tried mirror mode. The documentation refers to M579 (Scale Cartesian axes), however where would the best place for that be? In the start GCODE of a print file? "M579 U-1" is needed to "scale" the U axis in the negative direction.
@Danal
It's a good recap. Only the moves aren't not needed because the offsets can be defined by G10 Pxxx in config.g.
I'm waiting your come back.
Thanks again. -
@sebkritikel
It works ! Thanks a lot. It's strange I need to map the driver 5 with the number 3 but the essential is that it works.
For mirror, I've put the M579 U-1 in tpost3.g and M579 U1 in tfree3.g for return to normal direction when T3 is unloaded.
Thanks again. -
@Danal it is no longer worth to search the solution, @sebkritikel found it. Thank you
@noisettetbou said in U axis don't print:
@sebkritikel
Thanks again.Nice, glad to help! Good idea on M579 in tpost3.g and tfree3.g!
To understand why it is X3 instead of X5, reread M584 https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
3 or 5 does not mean driver, it means axis. The axis value is from XYZUVWABC, with X starting at '0' -
@sebkritikel @noisettetbou @Danal Thanks for your work on this thread! I really didn't have much of a clue where to start with IDEX. If you have any comments to update the IDEX page in the wiki here , or specifically this section , can you let me know and I'll update it?
Actually, looking at the IDEX wiki page, most of the info seems to be there?! Perhaps just a bit about the X parameter mapping using the order XYZUVWABC, where X=0, Y=1, Z=2, U=3 etc?
@droftarts said in U axis don't print:
I would agree that most of the info is there, but adding additional clarification on the X parameter mapping would be great, as well as a small section on M579 for mirror printing in the area discussing tool generation. Thanks!
@sebkritikel I've added a bit to the X and Y parameter description in https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M563_Define_or_remove_a_tool
I've added a similar note here: https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian?revisionid=HEAD#Section_Creating_a_tool_that_uses_more_than_one_carriage_to_print_multiple_copies_of_an_object
And described how to set up the mirror tool, and M579, here: https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian?revisionid=HEAD#Section_Sample_IDEX_tool_configuration
@sebkritikel OK. It's good to know the M594 means axis because I've got a project of printer with 2 X and 2 Y. Thank you
@droftarts It's cool you've got added this notes for the futures IDEX users. Thank you.
@noisettetbou You probably meant M584 and not M594.
undefined VA3Dnimers referenced this topic
