Another Predator
Results of the macro below.
M98 P"0:/macros/Probe test"
G32 bed probe heights: -0.078 -0.065 -0.065 -0.103 -0.090 -0.078 -0.090 -0.090 -0.090 -0.065, mean -0.082, deviation from mean 0.013
Thanks for help
@Carlo Your repeatability isn't as low as mine, but it still seems well within reason:
M98 P"0:/macros/ProbeRepeatability.g" G32 bed probe heights: -0.036 -0.036 -0.042 -0.036 -0.036 -0.042 -0.036 -0.042 -0.036 -0.036, mean -0.038, deviation from mean 0.003
When you run the delta calibration, are you doing it with the bed and nozzle cold or hot? My macro for calibrating heats the bed to 60C and the nozzle to 130C before it calibrates.
@Carlo If you're probing the bed with heaters on, turn them off by adding B1 to your M558 command. To quote @dc42 here https://forum.duet3d.com/post/97669
The reason we keep the heaters off during the recovery time is that some probes (e.g. BLTouch) need to recover from the effects of the magnetic field generated by the bed heater.
@NexxCat
Hi NexxCat,Hot..220c hotend 70c Bed....I'll set the heat as you have mentioned.
Thanks
B1 added Thanks droraft.
Results at 110c and 60c
G32 bed probe heights: 4.041 4.053 4.041 4.066 4.041 4.053 4.053 4.053 4.053 4.066, mean 4.052, deviation from mean 0.009Thanks
@Carlo said in Another Predator:
0.009
That's pretty darn good. Some mechanics (switch and/or overall printer) may do better... but that's a very good number on its own.
That's an excellent result, though I'm curious as why the probe heights are now in the positive and last night they were negative. That offset would certainly explain why nothing is sticking to the bed.
Ahh apologies I did change the endstops.... had to the only thing I hadn't changed adjusted the height so now..
G32 bed probe heights: -0.196 -0.196 -0.196 -0.196 -0.196 -0.196 -0.196 -0.196 -0.196 -0.184, mean -0.195, deviation from mean 0.004
Better ?
Thanks
@Carlo Yeah that looks fine. Hm. What is your current Z offset set to? In config.g you're after the line like:
G31 P100 X0 Y0 Z-0.210
Sorry if this has already been mentioned in the thread, just looking for things at the state of play right now.
No that's fine I'll add that in....not sure I want to click upload now don't want to be disappointed ...or cry in front of dudes!
Sorry I didn't read that fully Z-0.06
This is the result I think everyone looks and thinks it's too far from the bed but it's not actually completing the print move it's changing direction before it should in the picture you can see where the print does a U turn on it's self so it never joins the print together it just doesn't complete the move almost like the radius is wrong like the circle is smaller than it is I'm watching it and it does not complete the circles or arcs it never makes it to the end it changes direction and doesn't go back to finish it.
Where it has printed ..it stuck and the outer ring is on the second layer but there is a gap in it.. as have all the arcs and full circles they all have a gap in them and relative to the size the outer are bigger gaps than the inner i.e. the further out it goes the bigger the gap. -
@Carlo
Have you re-sliced that bed level print, or are you printing the gcode that came with the predator? -
It's re-sliced and I have one sliced by another user on these forums they are both the same in fact all prints are the exactly the same.
I wanted to rule the file out so another one of you extremely helpful users kindly sliced it for me to rule the file out for my own sanity. -
@Carlo
Give me a few minutes. I'm going to craft a gcode file for you to run, based on my startup settings and prime line. If you want to try that, we'll see what happens? -
Really appreciate your help and well everyone's help to be honest
That file prints fine on my linear plus and ender3Cheers
Test.gcode
Try printing that. It contains my startup code, the calibration of the printer, the prime line, and a single layer 40x40 square.Unless things are going really wrong, let it finish and take a picture. Obviously if it starts to make a real mess, stop it and photo that instead
You will need the web UI open as the calibration has a user prompt to make sure the nozzle is clean. Lastly, are you cleaning your bed with anything? If you've got isopropanol alcohol handy, give it a wipe with that whilst cold.
Thanks for this I'll try that now...Yeah I clean it with brake cleaner ..acetone I'll clean it first and always have to wipe the nozzle.
Thanks
