Extruder motor 3 and 4 no power to extrude
if you change the wiring e1 & e2 to e3 & e4 (switch off the board before) does the problem follow the motors ?
@SIam said in Extruder motor 3 and 4 no power to extrude:
If I change the motors, the problem is the same.
Will replace the expansion boards. I suspect that the problem then resolves. It's not the cables and motors. In my opinion, G code is also correct. I can not judge whether it is a software problem. -
that's how I see it too,your config.g is so far ok so it can only be the expansion board
I got another expansion board today
and of course tested it. Unfortunately, I was happy too early. The problem still persists. It wasn't the cables and motors that I tried with another ender today.
maybe it's because of the software itself
@Beat said in Extruder motor 3 and 4 no power to extrude:
FIRMWARE_VERSION: 2.01beta1(RTOS)
You're on an old version of the firmware. Have you tried the latest? https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
Firmware update instructions: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
I can't see any particular problem with your config.g. However, you also have M501 in your config.g. Please post your config-override.g file.
@droftarts said in Extruder motor 3 and 4 no power to extrude:
I can't see any particular problem with your config.g. However, you also have M501 in your config.g. Please post your config-override.g file.Ok have Duet Maestro (firmware version 2.03) on it.
With M501 I got the following.
Warning: Macro file config-override.g not found.
Will now install the new version 3.05.1. -
The solution can be so simple. Update successful. Test Jupiiiii it works !!
Many thanks to @droftarts and of course @slam
Now I can do the first test print soon.
@Beat I think support for the Maestro Dual Stepper expansion was added in 2.01, as the only mention in the Whatโs New document is
On the Duet 2 Maestro, the 2 optional add-on drivers are now assumed to be TMC2224 with UART interface
This may not have been in 2.01 beta you were running. If you had 2.03, that should have worked.
OK installed 2.03
@Beat send M115, post response. 2.05.1 is the latest, has many improvements over 2.03.
IanM115
FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2019-06-13b2 -
@droftarts
So far it works. The first test print was completed. It "prints". Well not where I want it yet.
