Duet Wifi board. Can i use a USB Print Server to get to DWC?
@jallen810 said in Duet Wifi board. Can i use a USB Print Server to get to DWC?:
M589: Failed to configure access point parameters
did you also run M552 as posted?
Danal said in Duet Wifi board. Can i use a USB Print Server to get to DWC?:
Via USB or console tab on PanelDue screen:
M552 S0
M589 S"SSID" P"password" I192.168.9.1
M552 S2 -
@bearer Success!! Thank you Very Much! Now i just have to get the config file fixed and i will be set!
Now that you have access to the web interface you can also update your firmware and web control.
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
Do put M552 S2 in the otherwise empty config.g first, so you don't have to connect the USB if you reboot the board.
@bearer said in Duet Wifi board. Can i use a USB Print Server to get to DWC?:
I did notice that when i unplugged the USB and the board shut off, and i turned on the machine, the AP was no longer working, does the M552 S2 in the config file, essentially make that AP "persistent"?
Its already persistent, but default to disabled. M552 S2 only enables the wifi module.
So in a way, yes.
@bearer Our IT is funny about using WiFi on unknown equipment. Above my pay grade.
Essentially, i just want to be able to access it on our network (LAN) from my laptop <10ft away.Just tell them they are stupid. Why would an ethernet connection be more secure in relation to unknown equipment? Hell, I think there is much more security applicable in WiFi then in ethernet! Have them add a VLAN specific for your printer (and laptop). Or (if they are using cheap home-grade equipment) bring your own wifi-router and plug that into an ethernet socket. This sounds more like "we don't want to support that"...
So in a way, yes.
Good explanation. Thank you. I am just glad to have control from my computer now.
@DeltaCon This sounds more like "we don't want to support that"...
I couldn't have said it better myself, alas, the folks in IT mustn't be trifled with because we need them for production related machines. So I am in between a rock and a hard place. The good news is, i found a work around and IT isn't involved so everyone is happy
If IT had some skills they'd already be on your door looking for rouge Access Points so I think you'll be fine.
If you want to play it safe/paranoid you could add some macros ala wifi on/off to your PanelDue screen to minimize detection.
@bearer Yeah i talked to IT and they don't care about me adding this access point
