Fuse Removal
Sorry if this is too basic a question but can someone please tell me how to remove this fuse from the board?
All my pulling and tugging have produced no results.
Thanks! -
It is just a pull.
You can get a fuse puller, which will help a lot, at any automotive store.
@Danal said in Fuse Removal:
https://www.thingiverse.com/search?q=FUSE+PULLER&dwh=65e3cb24397af3
I like to use a flathead/slotted screwdriver between the fuse body and the terminals, prying one terminal at a time.
Thank you all.
long nosed pliers, place them in in the same orientation as the pencil, grip the fuse and use the connector as a fulcrum, lever the fuse out.
