DWC2 and nginx reverse proxy - cont.
I have decided it is time to pick up my reverse proxy endavours where I left them at the end of these threads 1 and 2.
The end goal is to have mydomain.com/dwc lead to well... dwc. A number of other locations are also defined in the same reverse proxy, doing various things. On the forum I have seen others using a catch all location block (ie. location / { } ) for this purpose. While this config works for me, is leaves out the /dwc part of what I want.
In the config below I started to experiment with adding locations for all the missing paths, but this cannot the way to go. Anyone more experienced that can explain to me how I can achieve what I want?
mydomain.conf
[...] location /dwc/ { include /etc/nginx/proxy_params; client_max_body_size 0; # Don't limit upload size and pass it on immediately without buffering proxy_http_version 1.1; # WebSockets need explicid http 1.1 proxy_set_header Upgrade $http_upgrade; # Make nginx treat this as a WebSocket proxy_set_header Connection "upgrade"; # Make nginx treat this as a WebSocket proxy_pass http://websocket; } location /css/app.0b5b36ba.css { proxy_pass http://websocket; } location /js/app.cc04b2b3.js { proxy_pass http://websocket; } [...]
nginx.conf:
[...] map $http_upgrade $connection_upgrade { default upgrade; '' close; } upstream websocket { server 192.168.1.55; } [...]
I don't think it's a nice solution to redirect static DWC2 resources. You may be better of building DWC2 with publicPath set to
/dwc
instead of/
in your case. This will create a new bundle that loads DWC2-related files from /dwc instead of /. -
@chrishamm said in DWC2 and nginx reverse proxy - cont.:
/dwc
instead of/
in your case. This will create a new bundle that loads DWC2-related files from /dwc instead of /.I agree it is not a nice solution, or even a solution at all. While rebuilding DWC2 custom for me, will most likely work, and I have though about it as well. I am not a fan of having to build firmware myself each time an update comes around. Unless I can convince you the publicPath should be set to /dwc by default
