Big enough Power supply?
Do i have a big enough Power supply? I have a Delta 200 watt power supply that was the original in my 3D systems Cube pro
2x bondtech slim nema 17
3x oriental .09 steppers, 2 z and 1 Xaxis (PKP244MD15A2)
1x oriental stepper y axis (PKP246MD15B2)
2x 50 watt mosquito heaters
2x SSR one for 110vac chamber heat, and one for 110vsz bed heater
Panel Due
Duex 2
Duet2 wifi
7x 24vdc fansIs there enough to run some led lights also
Given that the largest heaters are on AC power, the rest of the system doesn't use an excessive amount. I run similar hardware on a 200w PSU without issue. Including a long strip of LEDs.
This should help you do some more detailed reckoning.
