New RepRapFirmware config tool
@chrishamm Hi, great work. I try to use this tool in safari browser 13.04 bud I can not open/edit XYZ Offsets in the too tab. Could you tell me please how can I fix this?
Thank you
You should get a "popup" or "overlay" like this:
Does safari have any way to turn off popup blocking?
Please could you look at the issue in regards to selecting BLTouch as a probe type for the Ender3 template with RRF3 in the config tool.
It is currently greyed out and is unselect-able.
I mentioned it in a previous post and DC42 informed me he would look into it.
Veti gave me the lines I need for it to work, mapping the pins.
Thanks
Paul -
@PaulHew said in New RepRapFirmware config tool:
Thanks
PaulI can select the BLTouch with RRF2 and RRF3 but in order to select it with RRF3, you need to assign the PWM Control Channel on the I/O Mapping page first. Then you can activate BLTouch on the Endstops page.
@chrishamm Thanks for the fast reply!
I have a Duet Maestro board.
On the I/O mapping page I cannot select any of the 'PWM Control Channels (BLTouch only).
I can see them in the drop down but they are not selectable.My thinking was if I was able select BLT on the Endstops page it would automatically create the I/O mapping.
Edit: Also on the Endstops page I cannot select 'Z Probe' for the Z axis
Regards,
Paul.
@PaulHew You must set "Z Probe Mod Pin" to (not assigned) before you can use it in the input below. I'll consider that suggestion.
@reneh There was a problem in the configtool that prevented the popup from being shown on OS X. It has been fixed in the latest version (2.1.8).
@chrishamm Is there a github repo for the config tool where issues can be raised to make them easier to track like there is for DWC?
@jay_s_uk said in New RepRapFirmware config tool:
Yes, it's on GitHub.
@chrishamm Again, thanks for the speedy reply.
Ok I have done that and I was able to eventually select Z-Probe and then select BLT. Thank you.I program, but not what you clever guys write.
As another suggestion for the I/O mapping page, based on selecting the Ender3 template with a Maestro board could there be a tick box for say 'If using a BLTouch check this box'
Which then selects the correct options, using the Ender3 template with a Maestro board makes the changes needed to the I/O mapping page and the Endstop page.? -
Hi, in google chrome i get such a popup but not in safari. In safari popups not blocked. strange phenomenon. Is there any other safari setting in safari that i need to consider?
Thank you
@reneh said in New RepRapFirmware config tool:
Have a look at this guide …
Technically it isn't a pop-up, it's just a div. @reneh try to clear your browser cache and it should work again.
Hi all, it works. Thank you very much
Bye
