Duet 3 and jetson Nano?
@hanshogeland I just uploaded DSF builds for 1.0.4.0. Suggest you give those a try.
I'm seeing the same checksum issues. I think I have to tweak the drive strength and the timing a bit.
Working on it! -
@gtj0 great!
I figured it out. I stupidly forgot to set the MISO pins to TRISTATE so the data was getting corrupted.
Tested and things now seem fully operational.
Grab the new u-boot and dtb files from:
https://github.com/gtjoseph/jetson-nano-support/tree/l4t_32.2.1 -
@gtj0 Success!! Thank you fior your hard work of making it work Iแธฟ truly grateful
Just a quick update...
There are official 64 bit builds of Duet Software Framework available from Duet3D. All you have to do is create a file named /etc/apt/sources.list.d/duet3d.list with one line in it...
deb https://pkg.duet3d.com/ stable armv7
Even though armv7 is mentioned, you'll get the arm64 packages.
Then copy the attached gpg key to /etc/apt/trusted.gpg.d/duet3d.gpg.
duet3d.gpg.txt
The.txt
suffix was added just to satisfy the forum's upload restrictions so you need to remove it.Finally, do an
apt-get update
andapt-get install duetsoftwareframework
@gtj0 said in Duet 3 and jetson Nano?:
Yes, Iยดve been thinking about this for a while and just like that the update I was waiting for :)!
Followed your instructions and it worked like a charm, thank you so much. -
Those packages have been up there for a while now but both @chrishamm and I forgot to tell anyone.
I did a fresh install (both L4T & DSF) and I'm running into an issue:
Monitoring DCS shows "Kernel SPI buffer" warning & "Duet is not available"
jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer Duet Control Server v1.2.3.0 Written by Christian Hammacher for Duet3D Licensed under the terms of the GNU Public License Version 3 [info] Settings loaded [info] Environment initialized **[warn] Kernel SPI buffer size is smaller than RepRapFirmware buffer size (4096 configured vs 8192 required) [error] Duet is not available**
Here are my config files -
http.json:
{ "Logging": { "LogLevel": { "Default": "Information" } }, "Kestrel": { "Endpoints": { "Http": { "Url": "http://127.0.0.1" } } }, "KeepAliveInterval": 30, "ModelRetryDelay": 5000, "UseCors": true, "UseStaticFiles": true, "SocketPath": "/var/run/dsf/dcs.sock", "WebSocketBufferSize": 8192 }
config.json
"LogLevel": "info", "SocketDirectory": "/var/run/dsf", "SocketFile": "dcs.sock", "Backlog": 4, "SocketPollInterval": 2000, "BaseDirectory": "/opt/dsf/sd", "HostUpdateInterval": 4000, "ConfigUpdateInterval": 5000, "MaxMessageAge": 60.0, "SpiDevice": "/dev/spidev0.0", "SpiFrequency": 1000000, "SpiTransferTimeout": 500, "MaxSpiRetries": 3, "SpiPollDelay": 25, "GpioChipDevice": "/dev/gpiochip0", "TransferReadyPin": 13, "BufferedPrintCodes": 32, "BufferedMacroCodes": 16, "MaxBufferSpacePerChannel": 1536, "ModelUpdateInterval": 125, "MaxMachineModelLockTime": -1, "FileInfoReadLimitHeader": 12288, "FileInfoReadLimitFooter": 262144, "MaxLayerHeight": 0.9,
Additonally,
sudo systemctl status duetcontrolserver:
jpomo@jpomo-desktop:~$ sudo systemctl status duetcontrolserver โ duetcontrolserver.service - Duet Control Server Loaded: loaded (/usr/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: ena Active: active (running) since Mon 2020-01-13 13:09:55 MST; 589ms ago Main PID: 17421 (DuetControlServ) Tasks: 9 (limit: 4182) CGroup: /system.slice/duetcontrolserver.service โโ17421 /opt/dsf/bin/DuetControlServer Jan 13 13:09:55 jpomo-desktop systemd[1]: Started Duet Control Server. Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Duet Control Server v1.2.3.0 Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Written by Christian Hammacher for Duet3D Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Licensed under the terms of the GNU Publi
sudo systemctl status duetwebserver:
โ duetwebserver.service - Duet Web Server Loaded: loaded (/usr/lib/systemd/system/duetwebserver.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-01-13 12:52:11 MST; 18min ago Main PID: 4592 (DuetWebServer) Tasks: 19 (limit: 4182) CGroup: /system.slice/duetwebserver.service โโ4592 /opt/dsf/bin/DuetWebServer Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]: at System.Net.Sockets.Socket.Connect(EndPoint remoteEP) Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]: at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]: at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: warn: DuetWebServer.Services.ModelObserver[0] Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: Failed to synchronize machine model Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: at System.Net.Sockets.Socket.Connect(EndPoint remoteEP) Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo
As far as I know, I have set the correct GPIO pin and SPI frequency.
Any advice is appreciated!
Have a look at the note in https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Enabling_SPI I haven't tested this on a Jetson Nano, though.
@jpomo10 It's an easy fix...
Create a file named /etc/modprobe.d/spidev.conf and put 1 line in it...
options spidev bufsiz=8192
Then reboot. You should be good to go after that.
Thank you for your help on this.
This fixed the buffersize problem, but still getting Duet is not available:
jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer Duet Control Server v1.2.3.0 Written by Christian Hammacher for Duet3D Licensed under the terms of the GNU Public License Version 3 [info] Settings loaded [info] Environment initialized [error] Duet is not available
Any other ideas of what might be causing it?
Thanks!
What's the contents of /opt/dsf/conf/config.json ?
Also start duetcontrolserver with
-l debug
My best guess is that you don't have the GPIO pin for the transfer ready line configured yet. Unfortunately this part is a bit counter-intuitive because the pin index in the gpiochip device likely varies from the sysfs index but with the right tool you can dump the indices and figure out what device/index you need to use.
{ "LogLevel": "info", "SocketDirectory": "/var/run/dsf", "SocketFile": "dcs.sock", "Backlog": 4, "SocketPollInterval": 2000, "BaseDirectory": "/opt/dsf/sd", "HostUpdateInterval": 4000, "ConfigUpdateInterval": 5000, "MaxMessageAge": 60.0, "SpiDevice": "/dev/spidev0.0", "SpiFrequency": 500000, "SpiTransferTimeout": 500, "MaxSpiRetries": 3, "SpiPollDelay": 25, "GpioChipDevice": "/dev/gpiochip0", "TransferReadyPin": 13, "BufferedPrintCodes": 32, "BufferedMacroCodes": 16, "MaxBufferSpacePerChannel": 1536, "ModelUpdateInterval": 125, "MaxMachineModelLockTime": -1, "FileInfoReadLimitHeader": 12288, "FileInfoReadLimitFooter": 262144, "MaxLayerHeight": 0.9, "LayerHeightFilters": [ { "Pattern": "layer_height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "Layer height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "layerHeight\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "layer_thickness_mm\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "layerThickness\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 } ], "FilamentFilters": [ { "Pattern": "filament used\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)mm)(\\D\u002B)?)\u002B", "Options": 17 }, { "Pattern": "filament used\\D\u002B(((?\u003Cm\u003E\\d\u002B\\.?\\d*)m([^m]|$))(\\D\u002B)?)\u002B", "Options": 17 }, { "Pattern": "material\\#\\d\u002B\\D\u002B(?\u003Cmm\u003E\\d\u002B\\.?\\d*)", "Options": 17 }, { "Pattern": "filament length\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)\\s*mm)(\\D\u002B)?)\u002B", "Options": 17 }, { "Pattern": "Filament used per extruder:\\r\\n;\\s*(?\u003Cname\u003E.\u002B)\\s\u002B=\\s*(?\u003Cmm\u003E[0-9.]\u002B)", "Options": 17 } ], "GeneratedByFilters": [ { "Pattern": "generated by\\s\u002B(.\u002B)", "Options": 17 }, { "Pattern": ";\\s*Sliced by\\s\u002B(.\u002B)", "Options": 17 }, { "Pattern": ";\\s*(KISSlicer.*)", "Options": 17 }, { "Pattern": ";\\s*Sliced at:\\s*(.\u002B)", "Options": 17 }, { "Pattern": ";\\s*Generated with\\s*(.\u002B)", "Options": 17 } ], "PrintTimeFilters": [ { "Pattern": "estimated printing time = ((?\u003Ch\u003E(\\d\u002B))h\\s*)?((?\u003Cm\u003E(\\d\u002B))m\\s*)?((?\u003Cs\u003E(\\d\u002B))s)?", "Options": 17 }, { "Pattern": ";TIME:(?\u003Cs\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "Build time: ((?\u003Ch\u003E\\d\u002B) hours\\s*)?((?\u003Cm\u003E\\d\u002B) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B) seconds))?", "Options": 17 }, { "Pattern": "Estimated Build Time:\\s\u002B((?\u003Ch\u003E(\\d\u002B\\.?\\d*)) hours\\s*)?((?\u003Cm\u003E(\\d\u002B\\.?\\d*)) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B\\.?\\d*)) seconds)?", "Options": 17 } ], "SimulatedTimeFilters": [ { "Pattern": "; Simulated print time\\D\u002B(?\u003Cs\u003E(\\d\u002B\\.?\\d*))", "Options": 17 } ] }
@chrishamm Yeah I know which one he needs to use.
And yeah, 13 is the right pin on the nano
AFAIR I used this guide to figure out the right gpiochip index. You can further diagnose why DCS cannot connect by launching it with the
--log-level debug
parameter. -
@jpomo10 Turn on debug from the command line or the "LogLevel" in config.json
jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer Duet Control Server v1.2.3.0 Written by Christian Hammacher for Duet3D Licensed under the terms of the GNU Public License Version 3 [info] Settings loaded [info] Environment initialized [debug] Lost connection to Duet System.OperationCanceledException: Board is not available (no header) at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 965 at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean mustSucceed) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 154 [error] Duet is not available
