bulge after z seam when printing outer layer first
I actually did try changing belt tension some. It looked at first to me like it was overshooting with the Y axis.
It was oriented with the seam facing the front of the Y axis.
I will try a cube as you suggested.
@SIam What would this help disambiguate? Would it indicate if it is over-extruding in general or just at certain points?
As the spiralized without prime looks good for me, why are you using prime?
the cylinder looks good so far
your extruder runs smooth without any clicking noise? -
It does make a soft noise when it is retracting, but i wouldn't describe it as clicking. More like gears turning.
Since I haven't had a Titan before, i wasn't sure what to expect from it. I have it set at:
400 jerk mm/min
5000 speed mm/min
2000 accDIY, i was testing prime in the regular print also, so I thought I would just point out the conditions of the two different tests.
@RedMachine
Your jerk and acc is very low. On my BMG I use much higher values. -
@DIY-O-Sphere
What are your settings?
So I can know a range to start messing with. -
@RedMachine
Depends on the size of the motor.
In you case I would take the values of Phaedrux. They were pretty similar to mine (Pancake BMG direct) Currently I'm back on a bowden setup with a bigger motor.
https://forum.duet3d.com/topic/5982/typical-titan-extruder-settings/5?_=1578786524923
You also can increase your max. speed. The linked value is very high and only nessary for high speed printing. I would set that to 8000 mm/min -
@RedMachine
From that base you can try to increase jerk. But at some point your extruder will start skipping. -
it's 1.8, but I think they are similar. 17hs08-1004s.
Thanks for the link, I missed him saying that in that thread.
