bltouch v3.1 helpπ
@Phaedrux said in bltouch v3.1 help:
PT100
ok this is a confusing part im using pin 8 heater3 from here https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe and i'm using a PT100 -
In that case, delete
M307 H7 A-1 C-1 D-1 ;disable heater 7 to free up for servo signal for BLTouch
andM305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
config.g did i mention I'm 41 and shit a retaining most information. thank you very much for you're patience
just so you know what your dealing with this is a iture of my "temp" setup my Frankenstein mad up of abs
and also thats the way my bltouch stays after it hits home
@jobesynoob1234 said in bltouch v3.1 help:
But does it deploy, retract, and trigger as expected?
yes all macros work so i take it the red flashing light is normal:/ because when i move the z-axis up and home z again the probe stays retracted and moves up instead.
Not sure what this means exactly.
Is the BLTouch flashing red or just lit at all times?
@Phaedrux flashing
Flashing would indicate error state. At what point does it error?
@Phaedrux as soon as it probes the bed
But it stops movement as it should?
@Phaedrux i just tried to upload a video but files to big and yup it stops but I can't use home z again until I click on the alarm release and drop pin macro because it will just keep moving up on every press
You can add that command to the start of your homing files to make sure the probe is ready before homing.
Still doesn't explain why it's erroring. But if it works otherwise I'm not sure what else to say.
@Phaedrux yup thats why its driving me nuts π€―and being a noob don't help
tomorrow i will solder all bltouch wires to eliminate connectors and see if that helps. Thank you so much for helping me on this thing hopefully I will win
well that was a waste of time soldered wires made no difference!
i also forgot about the error message after i used the G30 S-1 that says the (Z probe already triggered at start of probing move) its very confusing how all macros work and the only macro that seams to work different is the self test because they say it keeps going until you give it another command. But for me it stops its self after a bit -
post a picture of all your wiring
That makes me wonder if the pin is dirty or damaged? Try taking it out by removing the set screw at the top of the probe body.
