Z axis issue: wrong movement (layers)
@zecchi this is my config.g :
; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Dec 29 2019 12:57:27 GMT+0100 (Ora standard dell’Europa centrale); General preferences
M550 P"ZecchiPrinter" ; set printer nameM667 S1 ; select CoreXY mode
M551 P"123" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z1600.00 E96.56 ; set steps per mm
M566 X720.00 Y720.00 Z30.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z1200.00 E4800.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E4000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X310 Y315 Z315 S0 ; set axis maxima; Endstops
M574 X2 Y1 S0 ; set active low and disabled endstops
M574 Z2 S2 ; set endstops controlled by probe; Z-Probe
M558 P5 H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y-58.5 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:300 Y12.5:297.5 S57 ; define mesh grid; Heaters
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M143 H1 S250 ; set temperature limit for heater 1 to 250C; Fans
M106 P0 C"Hotend" S1 I0 F1000 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 S"Hotend_0" D0 H1 F0 ; define tool 0
M911 S22.5 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@zecchi said in Z axis issue: wrong movement (layers):
1200 may be a bit too fast for your Z axis. Try reducing it by half. Perhaps it's missing steps or binding. Though this is likely offset by the very low acceleration value.
Can you test the repeatability of your Z axis? Set to a known position marker and then move the z axis up and down many times and see if it returns to the same starting position.
(0.26, 0.18, 0.24... )
What is the full step resolution of your z axis? You show that it's belted to the lead screw. Is there a gear reduction involved? Is the belt slipping the teeth?
The motor current for the Z axis is 1000. What is the rated current of the motor? Ideally you should set the current to be 70-85% of the rated max current of the motor.
You're using anti-backlash nuts. They typically are not necessary on the Z axis since there is constant downward force on the bed from gravity and the bed is always dropping away from the nozzle during a print. They can increase friction however to the point they cause binding.
Have you lubricated the lead screws?
@Phaedrux said in Z axis issue: wrong movement (layers):
Thanks for your replay.
I'll try later. -
There is a 1 to 1 ratio
Belts are quite tight, I don't think they can slip (I hope… no noises , nothing that make me to think they are slipping )
Ok, it was too low. I set 1200 mA (80% of 1.5A). Unfortunately the error doesn't disappear.
Have you lubricated the lead screws?I'll try to remove nuts and use normal ones. Also I'll try to clean and re-lubricate the lead screws
News:
-Repetitivety Is ok, tested with a dial indicator
-I've change the nut. Some improvements but the error doesn't disappear.Other advices?
it looks like a z-wobble dubble (tripple) check the Z-Axis motion this must be stable and run smooth (it can be a nightmare to find the right position)
@SIam
I've printed a piece in order to fix the lead screws at the exactly center of the two rods, quite good but I didn't solve the problem.Any suggestions?
Look for more sources of binding. The smooth rods and bearings would be my next target.
Also rods are checked. Z axes is absolutely perfect, tested with a dial indicator (only 0.01mm of error in 300mm ). I've also printed a jig in order to have the rods at the same distance.
But , layer are, still, inconstant (0.24, 0.18, 0.22 ecc...) And this cause the blob (I'm pretty sure about that ). -
@zecchi What is the pitch/lead of your lead screws?
The problem really seems to be similar to trying to print at a layer height that isn't a multiple of the full step resolution of the Z axis.
@Phaedrux
2mm pitch. (I ordered the 8mm pitch but it arrived wrong). -
@Phaedrux
I've shorter 8mm pitch lead screws. I'll try with them. -
2mm pitch.
Well there goes that theory.
With a 2mm lead, and 1.8 degree motors (deduced from your 1600 steps per mm on Z) your full step resolution is 0.01mm. So you have no limits there.
What are the motor specs?
@Phaedrux
So, if my layer height is 0.2mm isn't a problem, correct?Motor: 1.5A , 1.8°. Classic 17HS4401 stepper motor.
@Phaedrux
So, if my layer height is 0.2mm isn't a problem, correct?Correct
I'm unable to find a data sheet that seems close. There are many sub-models of 17H4401 between many manufacturers. I didn't even see any that were 1.5a.
Can you find a data sheet that seems to match your motor based on what you know about it?
@Phaedrux
Second line of this datasheet:
17HS2408-MotionKing.pdfNow I realize that the seller made fun of me selling this motor as 1.5A instead 1.3A (I re-cecked and in the description is written 1.5A
