Done something to my config, now all tools are gone.
OK so still no tools?
Off topic but thought I would mention it.
I would update to firmware 2.04.
Regards M208: There is a "short form" now M208 Xmin:max keeping all the values together in one command.
Regards the M565/G10 "pairs": You can use just one G10 command with both sets of parameters. Again keeping things together.
Still haven't seen the problem. Will keep looking unless you find it first.
Nope still no tools.
@cdl1701yahoo-com said in Done something to my config, now all tools are gone.:
OK I will have to look again.
Upgraded Firmware to 2.04.
Just an FYI, still no tools -
Just an FYI, still no toolsWell we are missing something obvious.
I think the problem is the drive numbers in the M563 command.
I just checked my config and even though T0 is drive 3 in the M584 it is drive 0 in the M563.
I think that drive numbers in M563 start at 0 for the first extruder regardless of the drive number in M584.
Try that.
Well that got my tools back but this is how it looks on my duet panel.
If I change the H parameter to use 1 & 2 then 3 & 4 go away but still shows 2000 temp reading which is obviously wrong! haha -
I don't think the heaters change numbers.
If memory serves they are always 0,1,2 on the Duet WiFi and 3,4,5,6,7 on the Duex5.
I have a duet panel but I have never used it.
Any Idea how to get 3 & 4 to show as 1 & 2?
No I don't. Someone should.
I never used my panel - it was just easier to use the web interface.
