New RepRapFirmware config tool
@smece Thanks for you time and file, i ll digg in
you are welcome, I'm sure there's much to be done there so post progress here so we can both learn from it
Hi Duet Forum.
I have spent 2 days on RRF3 and Duet 3. I was my first hours on it ... It's a pleasure, i like this board. I'm moving from another board + Marlin to this one.
Of course it was not so obvious, but with the Documentations (already great) and the forum postsss, I made good progress.
3 Axis+ Endstops / 2 extruders + Sensors + Fans / BED / Heated Chamber / ... everything works. few things are not working yet, i'll write other posts about them.I share here my config.g, hopes it could help :
; Configuration file for Duet 3 (firmware version ?.0??) ; executed by the firmware on start-up ; oct 2019 : X/Y/Z E1/E2 BED/CHAMBER OK - BL (not ready) SERVO (not ready) ; DUET 3 6HC + 1 extension board 3HC (address 1.) ; ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"QualupQ3" ; set printer name Qualup Q3 http://www.spiderbot.eu/qu3-high-temperature/?lang=en ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M553 P0.0.0.0 ; netmask M554 P0.0.0.0 ; gateway M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives ;M569 P0 S1 ; physical drive 0 goes forwards / driver 0 unable on this board M569 P1 S1 ; X physical drive 1 goes forwards M569 P2 S1 ; Y physical drive 2 goes backwards M569 P3 S1 ; Z0 physical drive 3 goes forwards M569 P4 S1 ; Z1 physical drive 4 goes forwards M569 P1.0 S1 ; E0 physical drive 1.0 on expansion board goes forwards M569 P1.1 S1 ; E1 physical drive 1.1 on expansion board goes forwards M584 X1 Y2 Z3 E1.0:1.1 ; set drive mapping 1 stepper on X, Y and 2 Steppers (Z3 instead of Z3:4 because Moteur Z1 not plug on Driver 4 at this time) on Z and Extruder M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E4074.37:4074.37 ; set steps per mm M566 X900 Y900 Z120 E150:150 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z1200 E1200:1200 ; set maximum speeds (mm/min) M201 X500 Y500 Z100 E250:250 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1200 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y250 Z300 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io6.in" ; X min active high endstop switch / pin io3.in doesnt work use 6 instead M574 Y1 S1 P"io4.in" ; Y min active high endstop switch M574 Z1 S1 P"io5.in" ; Z min active high endstop switch ;Servo ;not working for the moment ;M950 S0 C"io7.out" ;not working for the moment ;M280 P0 S1500 I1 ;not working for the moment ; Z-Probe ;not working for the moment ;M558 P9 C"zprobe.in" H5 F120 T3000 ; FW v3 BLTouch connected to Z probe IN pin ;M950 S0 C"exp.heater3" ; FW v3 create servo/gpio 0 on heater 3 pin on expansion connector ;G31 P500 X10 Y20 Z2.5 ; set Z probe trigger value, offset and trigger height ;M557 X15:6 Y15:195 S20 ; define mesh grid ; TEMPERATURE Sensors M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; BED temperature sensor M308 S1 P"1.temp1" Y"thermistor" T4606017 B5848 C0 R4700 H0 L0 ; head 0 temperature sensor on expansion board ==> DYZE 500 M308 S2 P"1.temp2" Y"thermistor" T4606017 B5848 C0 R4700 H0 L0 ; head 1 temperature sensor on expansion board ==> DYZE 500 M308 S3 P"temp1" Y"thermistor" T100000 B3950 ; Chamber temperature sensor M308 S4 P"temp2" Y"thermistor" T100000 B3950 ; CAMERA IR temperature sensor ; Heaters M950 H0 C"out0" T0 Q100 ; BED heater 3 uses the out0 pin, sensor 0 M950 H1 C"1.out1" T1 ; HEAD heater 1 uses the out1 pin on expansion board and sensor 1 ;M950 H1 C"1.out1" T1 A584.4 C256.6 D6.4 S0.50 ; HEAD heater 1 uses the out1 pin on expansion board and sensor 1 ==> DYZE PID Cartbridge M950 H2 C"1.out2" T2 ; HEAD heater 2 uses the out2 pin on expansion board and sensor 2 M950 H3 C"out1" T3 ; CHAMBER heater 3 uses the out1 pin and sensor 3 M950 H4 C"out2" T4 ; IR Camera heater 4 uses the out2 pin and sensor 4 ; Maximum Temperatures Currently (September 2019), RRF3 does not support M143. ;M143 H0 S380 C0 ; BED max Temp 300°C ;M143 H1 S500 C0 ; Extruder 1 max Temp 500°C ;M143 H2 S500 C0 ; Extruder 2 max Temp 500°C ;M143 H3 S380 C0 ; Chamber max Temp 300°C ; Minimum Temperatures ;M302 P1 S240 R240 ; minimun extruder 1 Temperature 240°C extrusion and retract ;M302 P2 S240 R240 ; minimun extruder 2 Temperature 240°C extrusion and retract ; Fans M950 F0 C"1.out7" ; Extruder 1 fan 0 !F1 don t work ... ??? on pin out 7 pwm on expansion board M950 F2 C"1.out8" ; Extruder 1 fan 2 on pin out 8 pwm on expansion board M950 F3 C"out7" ; Chamber fan 3 on pin out 7 pwm M950 F4 C"out8" ; IR Camera fan 4 on pin out 8 pwm ; Tools M563 P1 D0 H1 F0 S"Extruder 1" ; define tool 1 - F1 don t work... ??? G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M563 P2 D1 H2 F2 S"Extruder 2" ; define tool 2 G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C M563 P3 H3 F3 S"Chamber" ; define tool chamber G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C M563 P4 H4 F4 S"Camera IR" ; define tool IR Camera G10 P4 R0 S0 ; set initial tool 4 active and standby temperatures to 0C ; Custom settings are not defined
Hey !
I missed the announcement ?? Duet 3 available on ==> RRF Cofiguration tool here : RRF Config ToolThanks for that !!!!
@steevebecker give it a go, feedback requested
@T3P3Tony first test works well:
My conf:
On 6HC:- X-Y-Z steppers
- endstop X-Y-Z NC/low end
- Bed heater + T°
- Chamber heater + Fan + T°
- Filament compartiment T°
- Electronic compartiment T°+ Fan
then on 3HC - 2 Extruders - 2 Fans- 2 Thermocouples
- 1 Servo
- 2 filaments presence
- IR Camera T°+ Fan
Just a Question How to add a T° sensor with out a heater ? Bed/Chamber/Nozzle Heaters are possible but can I add a sensor alone on a I/O with the RRFCT ? same for a Servo
@steevebecker said in New RepRapFirmware config tool:
AFAIK you need to add these manually to your config.g as the config tool does not set them up for you.
See https://duet3d.dozuki.com/Wiki/Gcode#Section_M308_Set_or_report_sensor_parameters
Uf you give the sensor a name it should show up in the "extras" tab in DWC
the tool tabs does not allow to select anything else that E0 for extruder, heater and fan
@Veti I have partially the same problem
in the I/O Mapping Tab, I have added : +1 Driver for the second extruder, +1 Heater, +1 Fan
pin out everything
but then in the Tool Tab, tools there is only FAN0 available for any tool.
I/O TAB:
Fan TAB seems ok:
But then in the Tool TAB
ignore my comment above its working.
you need to disable thermostatic control for another fan.
@Veti Make sense ! It works
is this stable for duet3 config?? Also..... im setting up a duet3 as a cnc controler...
How about cnc stuff???? A tab for cnc config like for the spindle speed output setting, for turning on and forward and reverse. Configuring for a vac system for triggering through gcode.... maybe for coolant pumps through gcode..... probing like digitizer probe.....
@jlipavsky79 that's a good point, we do need to extend the config tool for CNC and Laser modes of operation. I hope some of the CNC experienced on the forum can suggest good options and reasonable defaults.
@chrishamm Hi, great work. I try to use this tool in safari browser 13.04 bud I can not open/edit XYZ Offsets in the too tab. Could you tell me please how can I fix this?
Thank you
You should get a "popup" or "overlay" like this:
Does safari have any way to turn off popup blocking?
Please could you look at the issue in regards to selecting BLTouch as a probe type for the Ender3 template with RRF3 in the config tool.
It is currently greyed out and is unselect-able.
I mentioned it in a previous post and DC42 informed me he would look into it.
Veti gave me the lines I need for it to work, mapping the pins.
Thanks
Paul -
@PaulHew said in New RepRapFirmware config tool:
Thanks
PaulI can select the BLTouch with RRF2 and RRF3 but in order to select it with RRF3, you need to assign the PWM Control Channel on the I/O Mapping page first. Then you can activate BLTouch on the Endstops page.
@chrishamm Thanks for the fast reply!
I have a Duet Maestro board.
On the I/O mapping page I cannot select any of the 'PWM Control Channels (BLTouch only).
I can see them in the drop down but they are not selectable.My thinking was if I was able select BLT on the Endstops page it would automatically create the I/O mapping.
Edit: Also on the Endstops page I cannot select 'Z Probe' for the Z axis
Regards,
Paul.
@PaulHew You must set "Z Probe Mod Pin" to (not assigned) before you can use it in the input below. I'll consider that suggestion.
@reneh There was a problem in the configtool that prevented the popup from being shown on OS X. It has been fixed in the latest version (2.1.8).
