Problem with temperature sensor mark 2000°
Hello when i plug the temperature sensor with the daughter board and the resitance the temperature on the the screen is 2000° someone know how to resolve it ?
@kyll We need some more information to answer:
- What type of sensor (mentioning daughterboard I would assume PT100 but please confirm that)
- RRF version (
M115
) - Have you configured the sensor? (
M305
for RRF 2.x orM308
for RRF 3) If so please post the condiguration
The sensor is this one :https://e3d-online.com/pt100-temperature-sensor and i'v tried to change the config file by typing M305 P1 X200 at the place of the heater
did you verify the resistance of the pt100 sensor?
did you connect it to the correct terminal?
just checking. you do have the duet daughterboard and not the e3d daughterboard?
when you enter M305 P1 X201 in the console(not the config) does it also show 2000?
that means it cant talk to the dauthterboard.
did you connect it the correct way round?
that is the wrong way.
compare the documentation
https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensorsthe spacer should line up
Ok but right now the screen show -0.2°
@kyll said in Problem with temperature sensor mark 2000°:
-0.2°
thats the 100 ohm resistor. now switch the channel
On it's working thank you so much
