Seems Mesh Compensation isn’t working?
So I have a Artemis. I really wanted to get the magnetic filament sensor working... so I upgraded to 2.03 after researching.
Immediately I noticed my first layers weren’t as good. And they were perfect.
So, after trying the old “first probe” macro supplied with the printer, I had the issue with the bed floating in space.
I solved it by, doing it manually through console. I set the Z offset and added to my config. Then did the Auto bed calibration several times, then saved. Then I did the bed probe and then saved it.
At first my layer was still not good.
But after re doing this several times and playing with the offset I got a mostly good layer.
But now, it seems high in some areas and low in others. I’m fairly certain it’s not using the bed compensation. It has a good heightmap and is calling the heightmap but it’s not compensating.
It’s close but not perfect.
Any ideas?
There's a delta related bug in 2.03. Try the latest 2.04 RC instead.
