Editing files in /sys/subdirectory???
@GeorgeM said in Editing files in /sys/subdirectory???:
Since I am using my machine for both printing and laser engraving, I am making use of the M505 command to use alternate configuration files. However it seems like I cannot edit the files in the directory under the sys directory. I have to put the card in my computer to edit them. Is there something I am missing or is that a request that should go in for an enhancement?
It works for me on the latest system Not tried it on v2 system tho
Just tested on V2 of DWC and it works ok there as well
@T3P3Tony said in Editing files in /sys/subdirectory???:
go to system and the files are there
Tony, I don't believe that DWC supports editing files in sub directories under /sys
DWC V2.x certainly supports having the directories and contents but what it will do with them I am not sure
@Dougal1957 said in Editing files in /sys/subdirectory???:
Having them, yes. Editing files in them??
@Danal said in Editing files in /sys/subdirectory???:
Yes I can edit them as well!
Yep, just answered my own question. Web 1.x doesn't let you, Web 2.x does. Thanks @Dougal1957 !!
Latest repository: https://github.com/chrishamm/DuetWebControl check under "releases".
@Danal Is "package.json" the file I should dl?
@GeorgeM go to:
https://github.com/chrishamm/DuetWebControl/releases
and grab the appropriate zip file for your Duet (duet 2 or Duet 3)
The contents go in the www directory
@T3P3Tony Never mind. I figured it out.
Well I spoke too soon. I dl from here
https://github.com/chrishamm/DuetWebControl/tree/next
which is the "next" tree of DWC.
It downloads a file DuetWebControl-next.zip
But when I install this from within DWC 1.22.6 I see it unzipping a lot of files and then a blank screen.
I have to copy my backup /www directory onto the card to get back up.
Do I have the wrong file? -
@GeorgeM go to:
@T3P3Tony Thank You. That works.
