Cura 4.2.1 Config help
Can you post the G-Code file somewhere, at least the lines from the beginning to Layer 5 or so.
There are comments in Cura files that show where layers start. They look like this ;Layer:10 -
What is your layer height, in cura, and what is the "first layer" height?
Do you have mesh bed compensation on or off in the Duet?
If you manually enter G1 Z0, does the nozzle move to either just barely touch the bed, or at most be a "paper slides with drag" away?
After the Z0, do G1 Z1 and do your best to see if the nozzle is really 1mm up. Or do G1 Zx and slide an object that is EXACTLY x mm tall, etc, etc.
The point of the last two bullets is to find out if your printer is doing anything physically different than what the G-Code asks. The point of the first several bullets is to see if the slicer is asking for the wrong thing.
@Danal said in Cura 4.2.1 Config help:
Can you post the G-Code file somewhere, at least the lines from the beginning to Layer 5 or so. Ill Post this when i get home.
What is your layer height, in cura, and what is the "first layer" height? 0.28 for drought print.
Do you have mesh bed compensation on or off in the Duet? Tried both, same result.
If you manually enter G1 Z0, does the nozzle move to either just barely touch the bed, or at most be a "paper slides with drag" away? Yes, use a "feeler Gauge"
After the Z0, do G1 Z1 and do your best to see if the nozzle is really 1mm up. Or do G1 Zx and slide an object that is EXACTLY x mm tall, etc, etc. I have checked this, can confirm its 1mm. I use this. https://www.amazon.co.uk/Metric-Thickness-Feeler-Gauge-0-02-1-00mm/dp/B0052IRYVS
bolded text
This is Cura gcode
;Layer height: 0.2
;MINX:120.473
;MINY:120.476
;MINZ:0.2
;MAXX:159.525
;MAXY:159.525
;MAXZ:10
;Generated with Cura_SteamEngine 4.2.1
T0
M190 S60
M104 S210
M109 S210
M82 ;absolute extrusion mode
M201 X500.00 Y500.00 Z20.00 E250.00 ;Setup machine max acceleration
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ;Setup machine max feedrate
;M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
;M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
;M220 S100 ;Reset Feedrate
;M221 S100 ;Reset FlowrateG28 ;Home
G92 E0 ;Reset Extruder
;G1 Z2.0 F3000 ;Move Z Axis up
;G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
;G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
;G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
;G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
;G92 E0 ;Reset Extruder
;G1 Z2.0 F3000 ;Move Z Axis upG28 XY ; Home XY
M561 ; Clear any bed transform that might be in place
G1 X150 Y150 F4000 ; Move Probe to middle of bed
G30 ; Do a single probe
M375 P"heightmap.csv.csv" ; Load my custom heightmap. Otherwise use G29 S1
G1 Z5.0 F4000 ; Move Z to 5
M141 S28
M83 ;relative extrusion mode
G1 F2700 E-1
;LAYER_COUNT:50;LAYER:0
M107
M566 X480 Y480
G0 F6000 X126.088 Y126.295 Z0.2
;TYPE:SKIRT
G1 F2700 E1
G1 F1200 X126.478 Y125.911 E0.02002
;LAYER:1
M140 S60
M106 S85
;TYPE:WALL-INNER
;MESH:Golf_Green_Marker.stl
G1 F2700 E1
G1 F1350 X139.677 Y146.891 E0.01563 -
Good stuff! Thanks for the complete answers. Everything looks OK in the first set of answers.
Regarding the G-Code:
@Shaun said in Cura 4.2.1 Config help:
;LAYER:0
M107
M566 X480 Y480
;TYPE:SKIRT
G1 F2700 E1
;LAYER:1
M140 S60
M106 S85
;TYPE:WALL-INNER
G1 F2700 E1
G1 F1350 X139.677 Y146.891 E0.01563We may not have enough of this file. Layer 0 (which will become the skirt) is being printed at 0.2 above the bed, which is fine (and you said this layer works). We need enough of the file to see the Z commands for the next several layers.
Please find ;LAYER:0 through ;LAYER:5 and post that.
@Danal Thanks, i knew i should i emailed the gcode to work so that i can update this.
Ill get to this as soon as i get home. I tried a different file last night and the same problem.
"but when it starts the skirt is printed to perfection. Now this is where i get stumped, as soon as the nozzle moves to start the actual job it doesnt lower down enough to get to the bed. The result is a mess. "I get the exact same thing, so watching this thread with interest.
Quick guess as to what's going on: you're using 'Z Hop When Retracted' (in 'Travel' section in Cura, you may need to turn this on to see it), for which the speed is set by 'Z Hop Speed' (in 'Speed' section, which you may also need to turn on) is higher than the axis can actually travel. This shouldn't be a problem, as the firmware will slow it down to the speed the axis can travel, except that you have set that speed too high in config.g, so it skips steps.
@Shaun Can you post your config.g as well, so we can see what the Z axis speed is set to?
@JuJuDelta Is it your Kossel (from your signature) that's doing this? Delta printers shouldn't usually have this problem, as they can move in all three dimensions at pretty much full speed.
@droftarts here you go
M350Z16 I0 ; configure microstepping without interpolation
M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout -
Your Z axis is limited to 180mm/min (3mm/s), which I think is the stock setting; my Cartesian machine (though dual Z motors) is set the same, and your other motor settings are stock. It may be that you need to test if it can actually do these speeds; it's possible there's more weight on the Z axis, so it actually has to be lower. Or, as you've got 4000 steps per mm (0.5mm pitch on your Z leadscrew, I think), at full speed the motor has to do 6 revolutions per second to move 3mm; it may just not physically be able to do this.Try sending
G1 Z10 F180
thenG1 Z-10 F180
to check movement. If you do this at Z=0, you should be able to see if it returns to the same place. If it doesn't, try lowering the feedrate from F180 until it does move reliably.In Cura, the Z Hop speed is set to 10mm/s, which my delta can do, but my Cartesian machine definitely can't! But the config.g setting will limit it to 3mm/s. I don't usually have Z Hop turned on on my Cartesian printer, as the slow Z movement can cause as many, though different, printing problems as having it switched off.
If this doesn't help, can you upload the gcode as @Danal suggested, then we can see what it's actually doing during a print.
@droftarts said in Cura 4.2.1 Config help:
G1 Z10 F180
thenG1 Z-10 F180
Super, ill try drop the speed and also removing z hop.
Morning, ok so changed the speed and removed the rim. This time is printed but the layers where way to far apart leading me to the conclusion that my Z steps are way off.
My Config.g
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 19:45:33 GMT+0100 (British Summer Time); General preferences
M550 P"CR10" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z4000.00 E1222.00 ; set steps per mm
M201 X500.00 Y500.00 Z10.00 E250.00 ; set accelerations (mm/s^2)
M208 X280 Y280 Z350 S0 ; set axis maxima
;M557 X10:280 Y35:270 S12.6 ; Define mesh grid for full bed print
;G31 X-43.2 Y31.9 Z2.132 P25; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops
;M558 P5 X0 Y0 Z1 H7 F500 T4000 ; Set Z Probe to type Switch or Digital output where Z probe connector is used
;M31 P25 X0 Y0 Z1 ; Set Z probe trigger value, offset and trigger height; Z-Probe
;M574 Z1 S2 ; set endstops controlled by probe
M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P5 H1 F500 T5000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X8.5 Y-50 Z0.38 ; set Z probe trigger value, offset and trigger height
M557 X5:205 Y5:205 S10 ; define mesh grid; Heaters
M143 H1 S260 ; set temperature limit for heater 1 to 260C;Disable Heater to free up PWM channel
M307 H7 A-1 C-1 D-1 ; disable heater for BLTouch; Fans
M106 P0 S1 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M501 -
4000 steps per millimetre on Z looks like an order of magnitude too high...
@grizewald said in Cura 4.2.1 Config help:
With the sole exception that he is using a M5 threaded rod. But yes, more common these days are TR8x8 lead-screws which have 400 steps/mm.
Aaaahh yes that should be 400. My fat fingers again. Will fix and test.
Funnily enough I use M5 rod on mine, so Z4000 looked right to me! I think I remember thinking "I wonder what a CR10 has for leadscrews?" at the time I wrote it, but then forgot!
@Shaun You can probably turn the speeds for Z back up now, as the motor will probably be able to lift the Z much faster now, assuming it has enough torque to move the Z that fast. But do test it at it's maximum speed.
Could this be it?
;FLAVOR:RepRap
;TIME:194
;Filament used: 0.0936418m
;Layer height: 0.2
;MINX:131.371
;MINY:132.221
;MINZ:0.2
;MAXX:148.663
;MAXY:148.664
;MAXZ:10
;Generated with Cura_SteamEngine 4.2.1 -
@Shaun That just gives the minimum and maximum coordinates this print will reach for every axes. In this case your part is 10mm high according to these comments.
And there I was feeling silly after wilriker's comment, but I was fairly sure that in all the pictures I'd seen of the CR10, it was using a lead screw and not a threaded rod.
I feel vindicated!
Hope it fixes your Z height problem.
Ooops! Besides being the wise-guy that I am sometimes (=most of the time
) I actually wanted to express that I think you were right. Sorry I did not bring that across.
Still struggling to get this resolved, any other ideas i could try? Thinking i should scrap Cura and try something else to see if it resolves the problem.
