Endstop switches doesnt work
Check your wiring. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
Connect the switch between GND and STP (the outer 2 pins of the 3-pin connector). Note: this is not the same as on RAMPS.
We recommend you use the normally-closed contacts of the microswitches, which are generally the outside two connections on the microswitch, and set the signal polarity to active high (S1) in the M574 command.`See wiring diagram: https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
As others have pointed out, only X and Y endstops will work with your current config.g
@bearer said in Endstop switches doesnt work:
faster to look at the endstop leds than to use m119,
That only works if you can see the board when you press the switch, some put the boards in boxes and cant see the led's
@goodchrhere said in Endstop switches doesnt work:
Thermistor are right, the thermistor from bed and the thermistor from extruder 1 are in function.
they may be displaying a temperature, but when the temperature is hotter than room temperature it will display incorrect results.
@droftarts i checked my wiring 3 times. i measured with a multimeter on the plug, and ih have signal or no signal, but the duet doesn't recognize the signal. i know that only work in x and y because my config.
But x and y doesn't work. -
M574 X1 Y1 S1can you manually put this command in the console and try again?
post the actual output of M119 before and after the closing the endstop -
@veti i will do that today or tomorrow evening.
Looking at https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
... where exactly did you plug in the two wires coming from the endstop switches? -
@themelle i did that, i checked the wiring 3 times.
@themelle said in Endstop switches doesnt work:
... where exactly did you plug in the two wires coming from the endstop switches?This.. we need pictures of where the switches are plugged in to the switches and the duet. And dont take it that we are saying you are wrong we are only trying to help you, so for us to do that we need to see if there is anything wrong you might have missed.
@calvinx okay i will make photos today or tomorrow evening.
thanks for your help -
okay, i dont know, i had new wired and x and y works. i'm an idiot xD
What i have to chance in my config, to active z with the same switch? -
@goodchrhere I'm glad you got it working!
To have Z axis behaving as X and Y you should just remove the linesM574 Z1 S3 ; set endstops controlled by motor stall detection ; Z-Probe M574 Z1 S2 ; set endstops controlled by probe
from
config.g
I‘t works fine, thanks for your helps!
