rfm - RepRapFirmware FileManager [duetbackup successor]
Hi wilriker,
I hate to sound stupid, but how do I use it? Where do I put the files? And how do I access it? My system is Windaze 7 PC and a DUET-EtherNet controller.
Thanks in advance...3mm
Yep, -removeLocal now works.
You can't specify the remote directory as0:/
any more though. Not sure if this is intentional or not.$ ./rfm backup -domain duet0 /tmp/duet0 0:/ 2019/07/30 05:49:53 Fetching filelist for 0:/0: 2019/07/30 05:49:53 Directory not found
Doesn't matter to me, not sure if it's matter to others.
@3mm You download the release for your operating system. For Windows that would be
rfm-windows_amd64.zip
. Then you unpack that to a location of your choice. It is a command-line tool so you have to opencmd
and navigate to the directory where you unpackedrfm
to (alternatively: in Explorer right click while holding shift in the directory whererfm.exe
is located - this should provide a context-menu entry to open a command line in this directory).There you can simply run
rfm help
to get an overview and the available sub-commands. With
rfm help <subcommand>
you can see individual parameters of each sub-command.
@gtj0 said in rfm - RepRapFirmware FileManager [duetbackup successor]:
No, that's a bug.
I'll look into that.
@gtj0 Found it and fixed it.
Release v1.1.0-RC3
This can be found as usual on GitHub Releases page.
Another bug fix. There was a regression introduced in
v1.1.0-RC1
where it was no longer possible to specify the root directory of the SD card as0:/
. This is fixed in this release.Also this release candidate is intended to be the last one before final release of this version.
Arch User Repository Package
For Arch Linux users: I have submitted a package to install
rfm
via AUR: https://aur.archlinux.org/packages/rfm/This is available for
x86_64
,arm
,armv6h
,armv7h
andaarch64
Release v1.1.0
v1.1.0 has existed Release Candidate stage and is now available at GitHub Releases page or via Arch User Repository.
Reiterating the changes:
This release implements the persisting of-exclude
parameter values inrfm.toml
. These parameters will be persisted separately forbackup
andupload
command so they do not confuse each other.A new keyword
reset
has been added as a recognized value for the-exclude
parameter to delete all persisted excludes for the current command, i.e.rfm backup -exclude reset ...
will remove all persisted excludes for the
backup
command. Further-exclude
parameter after that (even in the same command) will add new excludes.Note that order is relevant, i.e.
rfm backup -exclude 0:/gcodes -exclude reset backup-dir 0:/
will backup everything in 0:/ since the given exclude for
0:/gcodes
was reset by the following-exclude reset
parameter.Bug Fixes
-removeLocal
was broken for files (working for directories though)- Sub-command
upload
would fail most of the times (this was fixed between RC3 and this version)
I'm trying to use your script, but I always get 'invalid character '<' looking for beginning of value' error. What am I doing wrong?
I'm using the amd64 version...
@fma This happens if the Duet responded with an HTML error page instead of a JSON error. I've seen this happen more often recently but so far have not found the cause.
Are you using the latest v1.1.0 final release above?
Also which sub-command does this happen for? Also you can use the parameter
-debug
to see the actual response coming from the Duet. This might give a hint what's going wrong. -
Yes, I'm using the final release.
The error happens with all commands, and
-debug
does not give much info:./rfm ls 0:/ -debug 0:: 2019/08/18 12:52:40 invalid character '<' looking for beginning of value
BTW, does it require a specific version of RRF? Im' running 2.02RC2...
@fma It should work with any version of RRF. Though the
-debug
parameter has to come before the location to list (in this case) or more general: before any parameter that does not have its own-something
prefix. -
My bad, I made a mistake in the device name! All seems to work fine
Thanks for your help.
@fma I'm glad it was that simple.
Release v1.1.1
v1.1.1 has been release and can be found at GitHub Releases page.
Changes
- New
-debug
option to output the HTTP requests being sent to RRF - Add CRC32 checksum as HTTP header to file uploads (supported by RRF 2.04RC3 and newer).
- New
This post is deleted! -
@wilriker Is it possibble to upload a file and start the print?
Best
@PCR No, this is not a feature of
rfm
. It was and is intended to manage files on the SD card but not further interaction with the RepRapFirmware. -
Ah OK. Thank you! BTW will it work with an DUET3 with a PI?
Best
@PCR said in rfm - RepRapFirmware FileManager [duetbackup successor]:
No, it won't because in that setup the files are located on the RPi and for Linux there are much better file managers than I could ever come up with.
