Rotating Magnet Filament monitor
Hello All
My filament monitor arrived and I got it installed today. @bmveee modified existing dyze mount to fit this one. I'm running Railcore II 300zl and installation was straight forward. I'm on 2.03 firmware. Got the cable crimped, disconnected my dyze sensor and connected the rotating magnet one.
Here is a picture of the mount and monitor mounted
Here it is in use:
I followed the guide and started with the settings provided. Kicked of a test print and at the end of the print got the results
Based on these my R should be 85:120 and L 25.00? is this valid calculation?
Going to test with more prints but so far noticed no issues. Also going to simulate jamming and filament run out tests.
Nice!!!
Updates please...
Where to buy the new sensor?
We will be listing them shortly as well
@duetal said in Rotating Magnet Filament monitor:
Yes to the L25 I would lake the R a wider window to start with maybe 70:130 or 60:140 until you have more data about any elasticity in your system and hos it responds to different filament types.
@t3p3tony I am looking forward to this.
@t3p3tony said in Rotating Magnet Filament monitor:
Got it. Will do. I only tried it with one filament so far.
calibration is done during every print? I noticed that after I powered down my railcore upon start M591 D0 showed no calibration data again. Is there a way to store this and use it ? -
The calibration data is just an averaging measurement over the duration of a print job, and gives you a rough frame for configuring the upper and lower ends of your filament sensor's sensitivity.
So nothing to store directly, just some input for you to perfect your printer's setup, especially the values for the M591 command in config.g -
@themelle said in Rotating Magnet Filament monitor:
So nothing to store directly, just some input for you to perfect your printer's setup, especially the values for the M591 command in config.gGot it. Thank you
Is it possible to use this to keep track of how much filament is left or used?
@duetal Not as it stands, however as an extension to the filaments management that would be useful. TBH you don't need the monitor for that - just add up all the extruded values for every print.
It is on the wishlist (https://forum.duet3d.com/topic/10595/filament-odometer-manage-all-your-filaments, https://forum.duet3d.com/topic/938/firmware-wishlist-and-priorities-for-duet-wifi-and-duet-ethernet)
In theory, but you could also do that without even using this monitor, since the extruder also knows precisely how much filament has been used (unless there's a jam or other slipping).
@T3P3Tony Nice timing!
Thank you. Is there a good way to track extruder filament usage? where do you even find it?
