G30 Insufficient Axes Homed For Bed Probing
I'm wondering if your motor directions and coordinate system is correct.
Can you verify for me that the 0,0 origin point is in the front left of the print bed?
-x movement goes to the left, +x to the right
-y movement to the front, +y to the backAlso where are the end stops in relation to x and y movement?
aaaaaaah! I didn't need that extra G90 prior to moving to the first probe point!
That g90 should be ok there.
Yes, all directions are correct, end stops are correct, I was putting it into absolute mode which was pissing it off! It seems fine now.
manual G code moves are as expected!
If I put the G90, it runs off to x300 y300+... if I remove it, it simply goes to the first probe position and homes Z as it's supposed to.. If it's working, am I ok to leave it out?
If that move doesn't work as an absolute position move than I suspect that your coordinate system is not correct.
Go through the movement section here again and do the motor direction test to verify that they are going in the right direction.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Movement_section
Also, can you post your config.g and homing files as they are currently?
All of the other homing files work fine however.. the buttons move everything in the right direction, what would you suggest I check? I mean if literally every direction I input is moving the right way, what would / could be off? wouldn't all homing files move in the wrong direction?
@steve-lynch said in G30 Insufficient Axes Homed For Bed Probing:
G90 ;absolute positioning
G1 X190 Y150 F6000 ;go to first probe pointThis should move the head to the center of your bed, but it's moving it into the endstops, right?
I have followed the tests on the link you sent several times.. yes, it moves as expected... I've been going back to that several times a day to keep a good baseline.. 0_1563565777236_config (1).g
It should move to the center, but instead it goes to the max position on both axes... end stops are at the low end, or opposite end from Max
M208 X-400 Y-400 Z0 S1 ; Set axis minima
M208 X300 Y300 Z360 S0 ; Set axis maximaYour axis minima is way off. I think there was a misunderstanding from the other day when I suggested changing the homing move distance to be -400. The M208 command should have stayed the same as it was.
Aw This Boy, He's so smart! if I were a Grandmother, I'd pinch your cheeks! Thanks man! That was exactly the issue.. I'll put that in the Mental Filing Cabinet.. End stops are actual coordinates. Homing is beyond Equal or greater.. Thanks so much!
I believe this is Case Closed!
aww shucks
