Hotend and Bed will not heat up. Previously worked on MKS Base board.
David,
Thank you I am just leaving the office, I will definitely check these. I am a slave for time currently so if I can get it working rather than wait for a replacement the better.
David,
to follow up even with your recommendations no leds lit up. I will try using the Atmel program and reflash the file onto the main chip first to see if that is an issue.
