Watercooled Smart Effector In Larger Effector || 4th Axis Design
Also, check out https://hackaday.io/project/158650-folds-and-hinges-technology-to-make-mechanisms/log/147838-ultra-light-extrusion-toward-the-graal for a very interesting and simple water cooling design.
@oliof said in Mounting a smart effector in larger effector - watercooled:
I saw that design when they released it but I do not think it is direct compatible with the E3D ecosystem that I use. Futhermore, it does not seem to be a likely fit for a smart effector.
@nxt-1 agreed on the extruder and it definitely is not a simple E3D drop-in. That said, the hotend/cooling part might fit. I heard mixed opinions on the ceramic heater with the thermistor in the nozzle though ...
This post is deleted! -
@nxt-1 said in Mounting a smart effector in larger effector - watercooled:
@dougal1957 said in Mounting a smart effector in larger effector - watercooled:
Sorry to put a dampener on your work but I don't think it will work, With the feed tube/blocks where they are I don't think you will have anywhere near enough clearance for the arms so your print radius is going to be severely limited and should you go beyond that limit you are likely to get an arm disconnection. I hope I am wrong but I would attempt to mount it and see before you go much farther. Also you might like to Check out the Zesty Kryo
No worries about damping , I have been thinking the same about clearance. In the current design, I have placed the ball joint connections at close to the edge of the smart effector pcb as I physically possible. If clearance issues arise, I can move them outwards or increase the spacing between the rods.
On terms of the Zesty Kryo, holy c**p. That seems just about what I was looking for. I have to interest into getting the rest of the Nimble ecosystem but I will definitely look at the Kryo. One issue, did Zesty discontinue the Kryo. I cannot find a source for it.
Comming back to the Kryo, I just heard back from Zesty directly and it seems that some users reported leakages appearing after a while. The guys over at Zesty make the right call and pulled the Kryo from sales until they can release a re-engineered version.
I've been continuing the work on this project. I've had a few failed print due to clogging, I assume from the heatbreak overheating. The last couple of print are doing fine however. I measured some temps with a thermocouple and the water rises to 30-35°C and the copper waterblocks themselves to around 44°C.
There is also a thread concerning monitoring the water temps with a 10K thermistor here.
And a thread about getting the part fan to work here.I have also decided to go full blow and mount some radiators on the 4th axis arm. Furthermore, I ordered an off-the-shelf water cooled heatsink from Germany. I plan to turn down the groovemount down to 12mm on a lathe and thread it to M12 myself. Not only is probably a better solution cooling wise but also way less tubes down at the effector. I feel the short tube in tight corners are in a way constraining the Z-probe action of a smart effector.
As described in a separate thread I now use a different way of mounting (the new) water cooled heatsink. This makes tubing a lot neater and should give better performance. I will keep this thread updated with the results once I find the time to properly do some testing.
@Nxt-1 Here is a quick status update. I am currently figuring out how I am going to implement the counterweight for the 2-2.5kg that the 4th axis weighs. The current plan is to cut a stack of disk out of lead sheet, so I can stack more weights as needed.
I'm using a FNU (http://reprapuniverse.com/catalog/store.php?cPath=44_155_157), and made a water-cooled block with a simple piece of aluminium (25x25x10), and a few holes:
It works fine. It does not require much water flow; my previous pump died, and I'm about to buy a peristaltic one.
I also made a version for a E3D-v6, for friends:
but for now, nobody tried it... It requires a new thermal heat-break, which can be found on ebay (M6 thread on full-length)
@fma I never heard of the FNU style nozzle/hotends, looks interesting. As for your waterblock, looks nice, clean and effective. I assume there are four fittings to avoid needing a channel machined in there and simplify the manufacturing process?
@Nxt-1 said in Mounting a smart effector in larger effector - watercooled:
Note that I broke one while doing 5 axis printing (forgot to lift up Z at the end of the print, and it collided with the part ). On the second one, I cut the tip of the nozzle, and only let the threaded part. This way, I can use any nozzle I want (like the Zatsit one, I'm still waiting for).
Exactly: just through all holes! I put a shunt tube on one side, so I only need 2 tubes for the water supply.
FNU are availabe here:
@fma same idea here. A smaller block is easier...
Delta
Core xy
For the delta, 2 holes drilled to M5. A M7 hole for the heatbreak.
For the core xy, 3 M5 holes and a M7 for the heatbreak.
I put a thermistor on the heatsink. The temperature rises to 29 degrees max in a heated enclosure at 40.
@tech-raton Looks good! How confident are you using those push fittings in a moving setup? I have seen their internal teeth do a number on the ptfe filament tubes after a while. Never to the point of actually cutting it, but still.
@Nxt-1 they come from my company. They are used in robotic application. They are good enough for me, for now...
The bowden tube inside another tube (in the delta) will break before the pushfit.
I use Festo pushfits: no leak so far (my hotend is now working for more than a year).
I'm going to start digging already, I should have this thread dug out by the time I am ready to post the latest update in this project
Enough digging up old threads for while, let's get to the update
From my last update post in this thread the design had already changed a little. Nothing in terms of function but mainly changing the way the radiators are mounted. The old way put a rather large moment arm on the carriage due to the large-ish overhang and their high weight. Below are two pictures illustrating the current situation.
From the top view one can see that the extruder is located on the Z axis centerline (0,0,Z). Assuming the effector could tilt fully horizontal and the bowden could exit the hotend at a 90° angle as well, the bowden length would need to be BedDiameter / 2. In practice the extruder mount can rotate around the Z axis 360° (within reason, as the bowden and electronics cannot keep turning in the same direction) and about 85° tilt from the Z axis. So the bowden will need to a tad longer to account of that and the bend radius at the hotend.
While this setup has worked quite well for me for about half a year, updates and improvements are always around the corner
In order to reduce the bowden length as much as possible I started a new revision. The main concept behind this revision is that the extruder itself has to move not only in Z height but also in X and Y location.
In the new version the arm itself has not really changed but the extruder mount has. The gimbal system with the two ball bearings has been thrown out and replaced by a single spherical joint. This allows the extruder to move with the effector and thus be mounted much closer to the hotend. The length of the bowden is now limited by the bend radius at the hotend side.
I am still waiting to finish printing all the revised components (my printer is printing other stuff atm) before I can verify my design. I have printed some test ball and cups for the spherical joint and they seem to work quite nice.
