Auto Bed Leveling Map on Tronxy X5SA
@phaedrux said in Auto Bed Leveling Map on Tronxy X5SA:
@pr0xyfl00d3r said in Auto Bed Leveling Map on Tronxy X5SA:
i have added Z Baby Stepping
Current Offset: 0.2 mm and seems to be ok, i think i can see a slight bubble to the sheet on the bedIf you find a consistent amount of baby stepping that you need you can add it to the G31 Z value to make it permanent.
Has the height map image improved at all? Is the first layer going down better?
Yes the map has flatten by half ish..
